first time at the dyno.... #s low?
best of about 5 pulls was 269 HP and 264 TQ
sound about right for my mods? (in sig) i know the mustang dynos give lower #s then the dynojets... but am i where i should be?
I did 280/292 stock on a mustang dyno...
graph:
http://lethalss.ssgraphix.com/images/SteveSSDyno.jpg
-Steve
Same engine....adding 15% for drivetrain loss that would put them 345-355 right about on I figured.
Uncorking these things seems to be the money move and you have longtubes already.
I agree w/v8maro, you seem pretty low unfortunately.
Here are my mods:
Volant
Z06 MAF
SLP Smooth Bellow
TB Bypass
SLP Ram Air H.O. Hood
160 Stat
Hypertech Programmer
QTP Long Tubes
X-Pipe, Dynomax Bullets
Yank SS3800 Converter
SLP Sub Frames
Drive Shaft Loop
BMR Boxed LCAs
QA1 Adjustable Rear Shocks
BMR Adjustable Pan Hard Rod
Poly Torque Arm Bushing
LCA Relocation Brackets
Air Bag (Passenger Side)
3.73 gears/w install
Skinies
MT ET Drags 26x10.5x15
Skinies
Since those are the only mods you have, your times aren't that bad. You could use a LS6 intake and a cam, you'd probably be pretty close to 11's with that.
Those bolt on guys running 11's have stripped cars. Don't expect to duplicate their numbers unless you get the weight down.
