C5/Kooks/Borla/Circle D/Cam only
The car was brought in bone stock with nothing but a cold air intake installed. Justin@NorthShore then got to work installing Kooks 1x7/8" headers, Borla "ATAK" exhaust and one of our custom cam packages.
Cam specs are 233/236 .619"/.578" 113lsa. The cam is paired with BTR Platinum springs and Comp Cams hardened chromoly push rods.
The car is equipped with a Circle D 3600 billet lock up converter as well and was locked during the pulls.
SAE corrected:
Uncorrected:
Plans are to take it to the track after purchasing a set of drag radials and gunning for 10's!
BTW it looks like these runs were recorded on our dyno, but they were not. I had my customer send the Win Pep files to me via email so I could upload them in our customer database to compare to other camshaft installs we've performed here at our shop.
To use a stock converter, the biggest cam I would recommend would be 225/226 .612/.570 114+3. If you wanted a tad more top end above 5000rpm in trade for some torque between 3000-5000 the cam could be ground with a 228 exhaust lobe instead.
That said, with what you have I would be more inclined to run this camshaft instead:
237/240 .622"/.588" 112lsa
With your combo, that cam would be a rocket ship. You have the compression, you have the port volume and valve sizing to allow that cam to shine.
Easy high 9's all motor on pump gas with that set-up in a fox body.
