FM13 dyno results
Some more tweaking and finding what it likes best will results in some good power gains.
Good luck..
I'll probably be calling you today after i can get my dyno graph and send it to you to see if you have any ideas. Where can I get the .030" shims?
I dyno'd 387rwhp with the same mods(except no HS rockers) with a TR224/112lsa
sorry it's so big
This looks like a sign of slight valve float. You could have a slight tuning issue also,but I would take care of the springs first.
me tomorrow as I would like to talk to you about spring/shim recommendations.
I may go ahead and swap out the ones I have since I have to remove them anyways to install the shim, plus they do have about 7k miles on them.
Thanks in advance,
Jonathon
Thanks in advance,
Jonathon
