Cam only dyno #'S....why so low
Old Apr 17, 2014 | 08:16 PM
1970camaroRS's Avatar
That's not a whole lot more power than stock, and it doesn't carry the power nearly as high in the RPM range. Those valve-springs MIGHT be barely adequate for that cam, but might be the culprit. I agree with everyone about the Flowmaster, ditch that POS for a decent straight-through design and you will pick up some gains. Even more if you get even the cheapest set of long-tubes.
Old Apr 17, 2014 | 08:59 PM
GMPPDEALER's Avatar
Found why it's so low, cut my muffler off, they stuck the inlet on the exit part of the flowmaster. It's hitting a wall in the muffler, pics don't do it justice.
Old Apr 17, 2014 | 09:01 PM
GMPPDEALER's Avatar
Pic of inlet they used
Old Apr 17, 2014 | 09:04 PM
GMPPDEALER's Avatar
From the edge of muffler outside, that wall inside is 1 1/4". With one 2" hole in the center not even an inch from the outside wall.. Wtf
Old Apr 17, 2014 | 11:36 PM
Friends don't let friends run Flowmasters. Get yourself a quality true-dual and long-tube combo using a Borla/Margnaflow/Maxflow/etc muffler, you won't be sorry. I'm running short-cased Jones Maxflow mufflers on my '78 Cutlass swap and I'm impressed by them. Especially for a $35 muffler.
Old Apr 24, 2014 | 08:36 PM
GMPPDEALER's Avatar
Going back to the dyno in the mourning with my new tsp LT's, Y and magnaflow. Wish me luck!!
Oh btw this magnaflow, single in single out 3" has some rasp to it. How do u fix that???..
Old Apr 25, 2014 | 02:01 PM
GMPPDEALER's Avatar
Well that was deff the problem, ended up with 368/364. I have a terrible rasp sound from 2-3k how do I fix it????
Old Apr 25, 2014 | 03:50 PM
HCI2000SS's Avatar
Which Magnaflow muffler is this?
Old Apr 25, 2014 | 03:53 PM
Sales2@Texas-speed's Avatar
LS1Tech Premium Sponsor
Pretty big jump 40rwhp is pretty significant. Crazy to think someone installed that muffler backwards
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
Old Apr 25, 2014 | 04:04 PM
GMPPDEALER's Avatar
Lol ya no kidding, I'm sure the tsp headers helped to . Now how do I fix this rasp sound? Lol
Old Apr 25, 2014 | 04:05 PM
GMPPDEALER's Avatar
18" oval 5x8, 3" in 3" out
Old Apr 25, 2014 | 04:29 PM
  #32
thunderstruck507's Avatar
What y pipe? A lot of the time the merge is the source of the rasp.
Old Apr 25, 2014 | 04:37 PM
  #33
GMPPDEALER's Avatar
Tsp y, and I cut the 2.5" off and put on a 3" to fit over stock pipe that goes to the back
Old Apr 25, 2014 | 04:41 PM
  #34
GMPPDEALER's Avatar
Pic, of the y
Old Apr 25, 2014 | 05:58 PM
  #35
GMPPDEALER's Avatar
I see maybe put a bullet muffler behind the y. Mag 14419?
Old Apr 30, 2014 | 04:07 PM
  #36
John02Hawk's Avatar
...Now how do I fix this rasp sound? Lol
This TSP catted y-pipe solved my rasp problems, although now it looks like they are no longer using Magnaflow High Flow cats in their current y-pipe but you may want to check if you can just get 2 cats welded in to your current setup: http://www.texas-speed.com/p-292-texas-speed-3-stainless-steel-catted-y-pipe.aspx
You may want to check out this thread for details or give TSP a call about it: https://ls1tech.com/forums/generation-iii-external-engine/1372646-what-catted-y-pipe-fits-pacesetter-longtubes.html
Originally Posted by PheonixLS1
Magnaflow Hi-Flow Heavy Metal cats part #99659HM. I got both of mine for 169.00 shipped. 3" in and 3" out body size is 4" so only .5 inches bigger all the way around of the inlet/outlet and they support up to a 6.2L. I put 3bolt 3" header flanges on my Pacesetters and on each side of my cats and then on my pipe so I could just bolt them in. That way if for some reason you ever have to replace your cats you won't have to cut your pipe over and over. Just pope the bolts out, put in a new cat with flanges and bolt it back up.
Old Apr 30, 2014 | 04:23 PM
  #37
TXsilverado's Avatar
a long dynomax bullet eliminated rasp on my past setups..it will also cut the noise down a lot while keeping the flow.
Old Apr 30, 2014 | 08:41 PM
  #38
Fat Jesus 808's Avatar
A bullet style muffler should solve the issue and not rob any power
Old May 5, 2014 | 10:31 AM
  #39
TransAmTimmy's Avatar
Just a quick reply to the numbers. Stock motor and BBK LTs and a cut out.
327 HP 332 TQ
Attached Thumbnails Cam only dyno #'S....why so low-tim-s-dyno-run-stock.jpg
