Peak power only at 4800 rpm
Old Oct 2, 2014 | 09:28 PM
LS1'35Ford's Avatar
Default Peak power only at 4800 rpm
I'm newer to tuning but am working on a truck of a friend of friend. It's my third engine with a similar sized cam, all right in the 222\222 range. The previous 2 peaked around 5800-6000rpm. This one is only at 4800 but it still runs clean of to 5800 when i got out of it.
Specs are
LQ4, 317 heads, 4L80e
howards cam 190245-12 222 225 112sep .561 .568
LS2 intake, 90mm tb
holley cast manifolds, straight 2.25" exhaust
fuel is within 1% of 12.7 at wot, 24 degrees of timing
Anyone have any ideas whats going on here?
Old Oct 3, 2014 | 11:02 AM
briannutter's Avatar
Any ideas on what the spring pressure is?
Old Oct 3, 2014 | 12:35 PM
WE TODD DID's Avatar
Where does the torque peak? Are the peak numbers low, or are they in the ballpark? Where is the cam installed at?
Old Oct 5, 2014 | 08:41 PM
DietCoke's Avatar
springs, undersized exhaust.
Old Oct 12, 2014 | 08:10 AM
redtan's Avatar
Tiny cam, low compression, restrictive manifolds (both intake and exhaust) and tiny exhaust. Did you expect this thing to be a 7000rpm screamer?
