How much power would this cost you on the dyno.
Just wondering, I now dyno's arent everything but I wasnt sure on just how much I would lose on the dyno.
I dynoed 440rwhp and 425rwtq on the stock rearend with 3.42 gears and stock driveshaft. I have since added a moser 12 bolt with 4.11 gears and an 10lb heavier steel driveshaft.
About what would I dyno now?
Thanks
Thanks
I had a stock 10 bolt with 3.42s and I dyno'd 382RWHP 376RWTQ, I installed an 8.8' read end with 4.10 gears and a heavy duty steel driveshaft and I re-dyno'd it and it made 375RWHP 375 RWTQ (same dyno) so it lost only 7 RWHP and 1 RWTQ. Your should be around the same area I would presume.
