[VR] 675rwhp / 584wtq C7 Corvette - VRSC750 Package w/Methanol - Build pics/dyno
This client came to us with a base M7 C7 Corvette that he had bought earlier last year. The car already had a set of wheels and tires on it from the guys over at Butler Tire and now he was looking to up the power. Having owned several 1,000+ horsepower cars in the past, he was not new to the modding world and after talking to him about the goals of his C7 Vette, we decided to run with our VRSC750 package plus a AlkyControl Methanol kit.
The methanol kit does several things that not only add power to the build but also increase the safety factory of modifying a stock short block. With the methanol hit, we are able to add more fuel to the car while increasing the octane rating while it is spraying. The meth injection also cools the charges which counteracts the heat generated by increasing power levels. The methanol increases the safety of the build while adding more power. It's a win/win for the customer and the car.
Modifications Installed:
VRSC750 C7 Package
- ECS Novi 1500 Supercharger
- ARH Longtube Header System w/high-flow CATTED X-pipe
- Vengeance Racing Camshaft Kit w/ VVT
- (VR Camshaft, VR Dual Springs w/ Ti Retainers, VR 3/8" Hardened Pushrods, C5R Timing Chain, Comp 850-16 Lifters, Comp Fuel Pump Lash Cap, Comp Cams Trunion Upgrade Phaser Limiter, GM MLS Head Gaskets, GM TTY Head Bolts, GM VVT Cam Bolt, GM Crank Bolt)
- Vengeance Racing High-Temp Spark Plug Wire Insulators
- Complete Professional Installation
- Custom ECU Calibration offered by VENGEANCE PCM, LLC.
The end result was 675.20whp / 584.85wtq!
Contact us today for more information or questions on our C7 performance upgrade packages.
