H/C tune results
Idk if I'd expect 470rwhp out of your setup, especially with smaller diameter primaries and a 78mm stock MAF. Bigger cam, FAST manifold, free flowing intake and bigger headers maybe.
Before you drive yourself nuts, check to make sure the tune is spot on and take it to a track to see what it traps. Till then, you're just pissing in the wind with guesses and random unachievable power expectations.
My 470hp guess was with it optimized with 1 7/8s, Fast 102 ported and a SD tune. I thought I clarified that but if I didn't I did now lol.
I agree about seeing what it traps. In the end the is a great indicator if it's just a heartbreaker dyno or the setup needs work. With the heads being ported it would be advantageous to get a better flowing intake as well.
As your car is now I would expect in the 420-430 range at least.
If it doesn't trap AJ if look into SD or a larger Maf and larger LTs paired with a cutout to bypass the CME.
definitely seems tune related.
So it's actually driving crappy too. That sucks. Hopefully you can find a good tuner, to take the time, to make it right.
The tune I received, from a reputable shop, is pretty good but I still have stalling problems.
It sounds like its running lean and your VE table is jacked. What was the AFR when you had it on the dyno? If he cant tune SD, he wont get the MAF tune either. I would find a new tuner.
A bunch of questions based on an internet thread questioning his work isn't going to make your car run better, but it will certainly build resentment and eventually he will probably just start avoiding talking to you.
I don't know enough about a SD tune in general much less one that doesn't use o2 sensors to offer much advice.
