Ls7 Fast 102 vs MSD airforce comparison
Old Apr 5, 2015 | 08:46 PM
ryan23's Avatar
Originally Posted by Goosecaddy05
Dude your definitely being hostile... Simmer down now... Its too easy to come off that way on the net even if you don't mean too
Roger, that. I apologize if you or anyone else felt that way too. I'll tap out..
CMS, thanks for taking the time to dyno the two intakes back to back.
Ryan
Old Apr 5, 2015 | 09:09 PM
HioSSilver's Avatar
Good to see some real world dyno testing on the msd. It looks to be a good intake but not the knock out blow we were all hoping for.
Old Apr 5, 2015 | 09:12 PM
gnx7's Avatar
Bummer the MSD didn't stack up better!
On another note.... the FAST102 also has more hood clearance for engine swaps like an RX-7. Another owner of an RX-7 test fit the MSD and it had no chance in hell fitting under the factory hood.... the FAST102 does.
Old Apr 5, 2015 | 09:21 PM
ryan23's Avatar
Mark -
I'm that owner. We're not done yet =)
Ryan
Old Apr 5, 2015 | 09:23 PM
aaronc7's Avatar
Keep us posted on the hood clearance thing. I have a C5 and hood clearance is already sketchy on the 102... I was hoping this new MSD would fit better.
Old Apr 5, 2015 | 09:27 PM
ryan23's Avatar
****... I wish I had the clearance you guys have... I'd have one of those fancy Maggie's =) But I'll let ya know. If there is one thing we can all agree on, no amount of lipstick will help this pig. But I'll take what I can gain...
Ryan
Old Apr 6, 2015 | 01:05 PM
1 Slow WS6's Avatar
The extra power up top could have come from being leaner so they seem to make the same power. Thanks for the test!
Old Apr 6, 2015 | 01:51 PM
1989GTA's Avatar
test!
True. But while on the subject, once you are past peak torque I see no reason not to lean it out some in the upper rpm ranges. IMHO around peak torque maybe have the AFR around 12.6 put by the time you are at 6500 or so I see no reason not to be around 13:1. Again IMHO in the higher rpm ranges the chance for detonation becomes quite small.
Old Apr 6, 2015 | 02:48 PM
Ryne @ CMS's Avatar
LS1TECH Sponsor
For everyone commenting on the air fuel ratio variance . That is from the tailpipe reading , the wideband in the midpipe showed less then a .1 afr variance . Regardless , with e85 in an NA appilication , anything leaner than .89 lambda generally hurts power more than helps it... FWIW
Old Apr 6, 2015 | 02:50 PM
redbird555's Avatar
I agree although Idk about running it to 13.5. like the msd but once the 2 are at the same afr i dot think there will be really any measurable distance
Old Apr 6, 2015 | 04:44 PM
blackz97's Avatar
I think the tuner addressed this in the post right before yours.
Originally Posted by Ryne @ CMS
For everyone commenting on the air fuel ratio variance . That is from the tailpipe reading , the wideband in the midpipe showed ledd then a .1 afr variance . Regardless , with e85 in an NA appilication , anything leaner than .89 lambda generally hurts power more than helps it... FWIW
Old Apr 6, 2015 | 05:05 PM
  #32
redbird555's Avatar
to be fair that post was posted right when mine was so i didnt see it. however I still think there is something amiss there. The afr was on for the whole rest of the run then right there it differed and thats where it made hp. Im not sure why they would log the tailpip afr on the graph as opposed to mid pipe. However thats mostly conjecture so well see what happens in the future. CMS did a great service here awaiting other results. I think if this intake is slightly better than the fast the new runners will put them right on par
Either way the 8-9 hp difference it had over the 102 doesnt make it a good case for milder combos. This is one badass c6z that obviously needs a lot of air, I dont see the gains happening on smaller setups but only time will tell.
Old Apr 6, 2015 | 05:26 PM
  #33
RedDeadG8's Avatar
was the FAST ported?
Old Apr 6, 2015 | 05:44 PM
  #34
dr_whigham's Avatar
The Scammer Hammer
Veteran: Marine Corps
This is cool and all, but the Vararam VRX fits the Vettes, fits the FBodys, and the runners are a world of difference in multiple areas.
Those results will be posted soon. I think eyes are about to get big...
Old Apr 6, 2015 | 06:44 PM
  #35
1989GTA's Avatar
"Those results will be posted soon. I think eyes are about to get big..."
I hope so and looking forward to the results.
Old Apr 6, 2015 | 07:47 PM
  #36
HioSSilver's Avatar
Here's a vararam test
Vararam VRX Intake Testing:
Old Apr 6, 2015 | 07:57 PM
  #37
miami993c297's Avatar
You certainly figure I am waiting to read about the outcome with this VRX Intake when R&D is completed...
Christian
Old Apr 6, 2015 | 08:52 PM
  #38
1989GTA's Avatar
You will notice in the above dyno test there was not much difference between the fast and the stock LS3 intake as has been reported in many tests. The Vararam had them both by a good margin. They have probably improved that since the test was taken.
Old Apr 6, 2015 | 10:52 PM
  #39
Mazzenger's Avatar
The VRX intake changed colors. It was white when they put it on, but the pull show it as black?
Old Apr 7, 2015 | 04:45 AM
  #40
dr_whigham's Avatar
The Scammer Hammer
The gray model shown was an early rendition. Production will be black...
