2006 Corvette Z06 620rwhp 523rwtq
#41
Getting the clutch spacing(fingers with TOB) is an absolute must in these cars for the hydraulics to function properly. I'd measure it 3 times with 2 different sets of eyes. Follow the guideline closely too. Make sure the details are followed like removing the spring before you measure, etc.
With the vettes getting to the clutch is a bear.
#42
That is why i want to go with a clutch where I'm not relying on the people installing the clutch who are clearly trying to make the quickest money possible. All they have to do is bolt the Katech right in and voila, it works perfectly as designed. Its got a 7000 rpm shift rating and I shift at 6600 or so so that should be just fine. Holds 800 rwhp on the street which is more power than I'll ever have. If Mcleod made a clutch for my car that just bolts right in I may go with them, but unil they do, I'm done with all clutches that need shims
#43
![Sad](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_sad.gif)
Have you tried with the key on engine off shifting into reverse & first? If it shifts easily that is a pretty good indication your not getting a complete disengage. I had the inspection cover off sliding a feeler gauge between discs & pressure plates to measure that. I didn't have enough travel with the slave so I added a shim which is what your condition sounds like. That did not fix my issue, helped a small amount. I finally upgraded to bigger Mcleod MC to get a complete disengage, the feeler gauge would slide in between the disc's & pressure plates. The problem as I mentioned earlier the pedal pressure was brutal.
Then I tried the LT1 conversion for a C5, as you are thinking Goose what a perfect solution. A stock factory clutch, nice pedal, Hi rpm shifts, for me a bit heavier setup....perfect. I won't get into the details here other than I'm happy with the current Mcleod RST combination......oh & no shim
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
#44
I didn't know you had this problem as well, I would think it is related to the death of your slaves. I've been thru hell with the aftermarket clutch's, I do my own R/R now since the last brand name shop only torqued 2 of the flywheel bolts
Imagine what happens as the remaining flywheel bolts slowly back out into the clutch disc.
Then I tried the LT1 conversion for a C5, as you are thinking Goose what a perfect solution. A stock factory clutch, nice pedal, Hi rpm shifts, for me a bit heavier setup....perfect. I won't get into the details here other than I'm happy with the current Mcleod RST combination......oh & no shim![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
#45
I entered into the privateer class, N/A, of the wannaGOFAST 1/2 mile event at Ocala, FL last weekend and won Fastest Naturally Aspirated privateer with a trap speed of 162.94. I'm very pleased with the results, given the cold temps and Pilot Super Sports. The car ran perfect, not a single hiccup.
Video:
Video:
