post up dyno numbers
These dyno results are so far apart. One guy w/ an 01 dynos 287 and another guy w/ an 02 dynos 318. If both of these are sae corrected what could be the reason they are so far apart. I know every car is different but 30 rwhp?
The WS6 or SS has a little bit of advantage because of their catback. So u will notice an average 5-10rwhp for the WS6 or SS over a normal T/A or a Z28. That is why i gained 33rwhp 24rwtq with just a lid and catback. The car went from 292rwhp 313rwtq to 325rwhp 336rwtq. U dont see an SS or Ws6 gain that much from a catback over their's. The dyno is here http://www.msnusers.com/CarsRelatedG...hoto&PhotoID=9
Its run # 2 and # 5. The others were after the headers and the last one after the cam.
My #s bone stock only with free ram air witch will not help you on a dyno are
305/329
305/340
300/329
96*
19000 miles
A4
My stock 1/8 mile time is in my sig
some people say it is vary strong some say it is average.
305/329
305/340
300/329
96*
19000 miles
A4
I know the ss and ws6 will be slightly higer. The two cars i am refering to is an 01z and an 02z that was posted on this thread.
"My stock 1/8 mile time is in my sig
__________________
02 Z28 FRA,K&N,A4
1/8 8.59 60FT 1.97@85.4
On stock tires "
Wish i could cut a 60 like that on my stock tires.
__________________
02 Z28 FRA,K&N,A4
On stock tires "
I think some off the difference is that A4 cars dyno lower than the M6 cars.
I used to think my numbers where on the high side on the dyno where I went. I dont know how these dyno's are calibrated.
I noticed that my lid only #'s where almost identical to Stoleit so thats why i posted.
With lid only my car ran 106.5 in quarter on the POS stock goodyear zero traction tires which I have since changed to BFG KD.
I figure 106.5 supports the 331 RWHP #.
285hp/308tq in 85 degree heat with 55% humidity, 16,700 miles on a 100% stock 2001 6 speed Camaro SS. I think its very low, but the car did come from Cali and it does have the California Emissions RPO code, I dont know if that will prevent it from making as much power or not.
Sweet Cheeks
I really don't think the Cali emissions costs you that much. My '01 SS is a Cali car, and with only a K&N FIPK & SLPP Dual Dual it put down 320rwhp/344rwtq. After using my Predator tuner to add 3* timing and lean the A/F from 11.9 to 12.7:1 it put down 334rwhp/356rwtq (corrected).
You may want to find somebody with A-Tap, HPTuners or a Predator to read the LTFT's, Timing & KR during cruise and WOT conditions and see if there is a problem there. Also I've seen quite a few LS1's where the throttle only opens 89-90% instead of 100%. Grinding the "bump stop" so the throttle opens 100% nets you an easy 7-10rwhp.
Good luck sweet thing. Nick
My 98 SS made 312hp with SLP Air Lid & SLP Loud Mouth at 95 degrees outside, With the addition of Jet Hot Coated headers & Off Road Y-Pipe it made 312hp at 101 degrees outside. Wish i had got a stock reading either way i am disappointed but maybe some tuning like everyone has told me to get will get some hp`s back.
286hp/310.5tq 3rd gear on ~80-85 degree day
'01 z28 2.73 A4. Lid & TB bypass (SOTP meter did not register much difference after these mods). I have hot weather 1500-2500 RPM ping on high octane gas although the dyno guy claims he did not see/hear any ping.
#35
here's a perfect example. the wife's car dyno'ed 327/331 at VHP on a dynojet 248E. then i take it to corvette masters for a dyno day and it dyno'ed 313/312. why? temp was 14* hotter, and it rained right after the last run. so humidity was 100%. here's pics of the graphs.
