Dyno Numbers - '99 Camaro 6-speed with long tubes + LS6 IM + air lid
Here are my dyno numbers.
Speed Engineering 1-7/8” long tubes + Y-pipe, air lid, dynomax bullet muffler + SLP LM1 axle back + street tune.
Had the car dynoed on a very hot/humid day (103.49 F, 27% humidity)
Made 353.88 rwhp / 355.47 rwtq.
![Name: camaro_dynograph_zpseqae8y6a.jpg
Size: 176.9 KB](https://ls1tech.com/forums/attachments/dynamometer-results-comparisons/646962d1501483218-dyno-numbers-99-camaro-6-speed-long-tubes-ls6-im-air-lid-camaro_dynograph_zpseqae8y6a.jpg)
If your AFR reading on that graph is accurate either your tune needs some work or you have a fueling issue. It appears to be around 14:1 when it should be at 12.6-13.0 for best power and being safe.
So either it's poorly tuned or your pump, filter, or injectors are limiting fuel. Either way it's not safe and I would resolve the issue prior to WOT pulls, especially under load on the street.
