C6Z gains 166/125rw 627/536rw
#43
Very impressive results Pray! Seems to me getting all that flow out of only a 275cc port might be a new benchmark for oem rect. heads.
What kind of specs are you getting our of LS3 for small CI applications my G8?
Jason
Jason
#44
Thanks, I just finished up another set of LS7's that outflowed the set on this car by 5-10cfm at different lifts and carried with gains to .700" on my bench. The last set went 382@.650" on my bench and 400@.650 at 28". The set I just finished went 382@.600 and 390@.700 on my bench. I would guess 410or more at 28".
I just roughed in an intake and exhaust on a set of LS3's I am doing for a 416 I am putting together in a couple weeks. All of my exhausts flow the same. LS2/3/7. The intakes went 349@.600 and 357@.700 which should correlate to 360@.600 and 380@.700 at 28" from past data. The low lift flow is what is actually more impressive. I will have to go measure the intake runner.
#45
The LS3 intake port came in at 269cc. I am going to do some experimenting with the short turn and a couple other spots where I could have left some material or removed some material. I am also going to mess with the valve job a hair. I am going to leave the way the valves are cut alone so that won't change the measurements. I didn't make any changes to the cross section and the intake port opening remains unchanged. I have noticed in the past that some guys are raising the port roof opening for a straighter shot at the port roof on the bench but I don't think it will be worth much with an intake on it. I will experiment with it and the intake port opening to see what I get. I would say the finished ports will come in around the 268 to 270cc size when I am done. I guess I should cc'd a stock port to see where it started the way I cc.
