2000 Firehawk, bolt ons, 358/357tq
Old Feb 27, 2016 | 02:25 PM
LilJayV10's Avatar
Default 2000 Firehawk, bolt ons, 358/357tq
Finally got the chance to put my car on the dyno at work. Dyno has been recently calibrated.
2000 Firehawk
Stock cam
LS1 intake
stock t/b
.040 Cometic head gaskets
SLP 25% U/D pulley
SLP lid
Fast Toys SSRA
180 t stat
Improved Racing crank scraper/windage tray
1 3/4 LT
3in ORYP w/ Flowmaster merge dual 3in/single 4 inch out, SLP dual/dual muffler
T56
Monster stage 2
3.90 rear gear
Old Feb 27, 2016 | 04:40 PM
HCI2000SS's Avatar
Great numbers. Especially with the LS1 intake
Old Feb 27, 2016 | 05:07 PM
LilJayV10's Avatar
Thanks. There's a few spots I need to clean up the MAF table a little but ran out of time.
I'm very fortunate to have a dyno at work. There are all sorts of things I want to test given, I have the time and the money to buy some parts.
We are a dealer for BTR so I am wanting to try out a couple of his camshafts and see what the differences are.
Old Feb 27, 2016 | 05:09 PM
madmike9396's Avatar
Nice numbers !
So you pulled the heads to run a thinner gasket?
Old Feb 27, 2016 | 06:28 PM
LilJayV10's Avatar
Originally Posted by madmike9396
Nice numbers !
Thanks I appreciate it. The car used to be H/C/I. I had a Comp Cam failure and the TEA 5.3 1.5 heads that I bought off the forum that were "rebuilt" had a bunch of valve guides wore out and it smoked like a freight train on decel.
Due to finances at the time I put the stock heads/cam/intake back on. I already had the cometic's so I used them.
Old Feb 27, 2016 | 06:43 PM
LilJayV10's Avatar
I had it at the track after I put it back to "stock" and it was trapping slower than a bone stock car. I put it on the dyno and found out my MAF was bad and went to about 1.08 Lamda 15:1 AFR above 4000rpm . I replaced the MAF and just now had a chance to put it back on the rollers.
I will say that the Frost mail order tune that I got a couple years ago (when I put the car back to "stock") was damn impressive (MAF table). My MAF/Lambda error was with in 5% above 4500rpm.
His tune was commanding PE was about .82 Lambda which is about 11.7 AFR, which I completely understand being rich and staying safe.
I leaned it out to .88 Lambda, about 12.7 AFR and made a few small timing changes and picked up 14hp and 9 ft lbs. This was back to back runs. I'm sure there is a little more power to be had but not much.
The low end of the MAF transfer table needs some work. I didn't have time to look at the VE.
Old Feb 27, 2016 | 07:37 PM
Cyris0014's Avatar
Great numbers for bolt ons.
If you need a car to try parts on, I am only an hour and a half away
Old Feb 27, 2016 | 08:14 PM
OK I got ya. Had me wondering lol
Old Mar 9, 2016 | 05:26 PM
Camaro99SS's Avatar
Well at least you've now established the shortblock is healthy and a good test mule.
Just curious where's your shop located? I grew up in Evansville but haven't lived there for 6yrs now.
Jason
Old Mar 9, 2016 | 06:01 PM
LilJayV10's Avatar
Jason
3300 Claremont Ave. It's about 6 blocks west of Reitz H.S.
Old Mar 11, 2016 | 06:29 PM
Camaro99SS's Avatar
Know right where it's at. I used to live off S. Werner when I went to USI. Didn't realize you all were doing performance work back then (04-05).
Jason
Old Mar 11, 2016 | 09:10 PM
LilJayV10's Avatar
Jason
We have been in that building for about a year and a half now.
Old Mar 12, 2016 | 05:51 PM
Camaro99SS's Avatar
Got it. I thought maybe you'd been there awhile as there was a shop on that stretch that always had some sort of muscle car or two for sale sitting out front. Good to know there's finally a shop with a dyno in the Evansville area that has LSX expertise. Best of luck on your endeavor!
Jason
Old Mar 12, 2016 | 09:11 PM
LilJayV10's Avatar
Jason
Thank you for the kind words.
Currently we are doing a 05 Vette build for a customer.
BTR blower cam, studs, D1, Forte fuel system, running on corn, RPM trans, diff, Z06 half shafts and a bunch of other stuff.
Nothing crazy, customer wanting to crack 650 or so to the wheel.
We are on Facebook if you want to check us out.
