Ls2 lacking power?
Old Mar 31, 2016 | 12:02 AM
Coltonzabolotney's Avatar
Default Ls2 lacking power?
I have a 2004 Gto with a 2005 Gto ls2 in it. It has Dynatech long tubes, catless, flowmasters along with 3 inch piping all the way back, btr stage 3 cam, fast 102, nick williams 102 tb, and a varam intake. It put 432/400 to the wheels. I feel like that's a little low. By what I could find on here a lot of people put 470 with a cam and intake. If you have a cammed ls2 please let me know what you make.
Old Mar 31, 2016 | 07:07 AM
gagliano7's Avatar
Checkout ls1gto.com there should be alot of dyno #'s there for goats.
Old Mar 31, 2016 | 09:26 AM
imma_stocker's Avatar
Which heads and what's been done to them?
Old Mar 31, 2016 | 09:50 AM
Stock 243s
Old Mar 31, 2016 | 10:38 AM
thunderstruck507's Avatar
mine made 418 rwhp through an automatic with unlocked stall with:
ported 799 heads
230/238 cam
longtubes, 3" duals
Fast 90mm intake (mild port)
underdrive pulley
I have serious doubts of making an honest 470rwhp with stock heads. A LS2 will make similar power to a LS6 if the same heads/cam are used...the cubes allow you to run better flowing heads/cam and still have good manners, the small jump from 5.7 to 6.0 in itself is not going to give you a large HP gain but it will help torque and move the powerband down.
As expected your car makes a little more power (10-15hp) than a 243 headed ls1/ls6 but about 20-30 more ft/lbs rwtq.
It takes a very well optimized and thought out combo to get 470-500rwhp from a 5.7-6.0 shortblock. There are ringers and generous dynos of course, but I'm talking averages.
Old Mar 31, 2016 | 11:28 AM
redtan's Avatar
I think those numbers are pretty good, especially if you're an auto.
I wouldn't really think that a cam only LS2 is truly around 470 unless it's a monster cam with all other supporting mods. Most likely what you are seeing with those kinds of numbers are either loose dynos or STD corrections.
Old Mar 31, 2016 | 12:40 PM
Rise of the Phoenix's Avatar
I agree, nothing wrong with those numbers at all. You ain't touching 470 rwhp with stock 243's in a NA setup. Time for some ported heads.
Old Mar 31, 2016 | 12:43 PM
redtan's Avatar
There's some cat in the dyno section claiming he's making 525rwhp with stock 243s...in a 346 no less. But that's a story for another day lol.
 Michael S. Palmer
Old Mar 31, 2016 | 12:54 PM
I want some of the stuff he's smoking...
Old Mar 31, 2016 | 01:13 PM
I think that guy's running those one off hand ported heads from the Stevie Wonder.
Old Mar 31, 2016 | 01:49 PM
Mavn's Avatar
"I MAID THEESE"
Numbers look Spot On
Old Mar 31, 2016 | 04:20 PM
exhaust fumes in a closed room?
There was a high altitude kid that claimed (with dyno as evidence but no time slip) his little WRX put down something north of 800awhp. Did it on oxygenated E85 using a gracious dyno pushing the tune to the brink without correction.
Not sure what happened to that one after it TRIED to make a pass and puked the driveline onto the track. Maybe they know each other.
Old Mar 31, 2016 | 06:07 PM
Jtm2085's Avatar
There was a guy local to me that made 470 with a custom grind cam and a fast 102. Stock heads 6 speed car
Old Mar 31, 2016 | 06:08 PM
Jtm2085's Avatar
Whoops it was a fast 92. https://ls1tech.com/forums/pontiac-g...-only-gto.html
Old Apr 1, 2016 | 05:19 AM
dude292's Avatar
I am running Trick flow heads, fast 102/nick williams throttle body and fast fuel rails and a vengeance racing "vindicator" cam comp cams trunion upgrade Yank 4000 and strange S-60 with 4.10's 435hp/390tq to the wheels on vengeance's dyno 2002 LS1 CETA
Old Apr 1, 2016 | 11:11 AM
kinglt-1's Avatar
That is Vetteboy...he runs 9's with a cam only Ls6 supposedly makes 525whp. The thread topic is about making 575+ whp from a 346 with a plastic intake and hydraulic cam.
https://ls1tech.com/forums/dynamomet...ossible-n.html
Old Apr 1, 2016 | 07:03 PM
HioSSilver's Avatar
^^^yup
I think op's numbers are a bit low. We make similar power with my #s converted to dyno jet numbers. And it's a bolt on ls6. A cammed ls2 should do better than me.
Old Apr 2, 2016 | 06:56 AM
redtan's Avatar
You make 432rwhp with a bolt on LS6
Is one of those bolt-ons a magnacharger?
Old Apr 2, 2016 | 07:37 AM
HioSSilver's Avatar
No magnacharger needed. Be the wrong blower anyway.
Yea if it was on a dyno jet it would make around that. Those numbers are through a 10bolt and it has a 9" now so that could hold it back a little. But i also making a few changes to what i am hoping will result in more power.
Old Apr 2, 2016 | 07:24 PM
mkvamso's Avatar
And hio comes in to spew more crap about his unicorn ls6.
Theres not a single car on the planet that runs good or makes good power compared to his
/thread
