What would an intake gain me? sorry :-)
Setup:
Fresh SBE LS1
Mamo 220's 60cc
225/227 .612/.614 114+3
Johnson 2110 SLR's
Manton 11/32" Series 4 PR's
Shimmed YT ultras 1.7
LT 1-3/4" headers
Dual Magna 3" cats
Dual 3" to 3.5" merge
3.5" catback custom with SS hooker aero muffler
ATI 10% UD
90mm Holley TB
Running SD
4.10 IRS
18x10.5 CCW's with 285/30-18 R888's
T-56
Monster Lightened LT1-S
SCR is about 11.56:1
DCR around 8.95:1
Quench at .032"
93 Oct and about 31* timing and not a sign of knock.
And the worst part.....LS2 intake....I ran out of fundage. :-) I know the LS2 is more or less between the LS1 and LS6 but I picked it up for stupid cheap.
Right now the car feels fantastic down low. Up to about 5000 it feels great. Falls a bit flat after that. I'm sure it's the intake but you never know.
Logistically the FAST 92 would fit best. I know a FAST 102 will just but I'd have to build a custom strut tower bar. Whichever I go with they'll be ported by Tony. I'm also rather attached to the Holley TB. Tuning it was a breeze and it's smooth as silk in the pedal. I've had other TB's that just felt terrible. The Holley has the low TPS % hump too. I'd probably consider running the CBM adapter for the FAST 102 before actually stepping up to a 102mm TB.
Just realized this should be in the bench racing section. Mods please move it at your earliest convenience.
Last edited by Exidous; May 11, 2016 at 09:33 AM. Reason: Forgot trans/bench racing
MAMOFIED FAST 92 (25-30) RWHP. ". "
Both will fatten up the torque band 2500-5500 RPM
Significantly, 20+ lb ft, and sharpen throttle response
Considerably!
I know the headers are a bit off from ideal but they cause enough ground clearance issues as it is and the car isn't even lowered.
