BTR stage 3 n/a cam... care to guess with me?
I hope it's just the pump. That's why I want to replace with a new one to rule it out. The only thing different with my system is that it has the corvette fuel filter with built in return line. And 30 lb injectors. I don't think any of those items would be the cause though
So the nitrous is definitely not the issue then. Are you positive those 30 lb injectors are enough? Stock are 28 lbs and in some cases a HCI LS1 can max those out. Just a thought
