tr 224 cam only
If I had it to do all over again I would have gone with a larger cam. I think I will have to upgrade my cam if I get a good set of heads.
Cajun
Cajun
Eric
Jeff Creech at Carolina Automasters. He is an excellent LS1 tuner and people come from three states away to get tuned there. I am running mid 12s at over 112mph with 2.1-2.2 60ft so the car is fast, just need to practice driving and put the DRs on
Cajun
If I can get up in the 360-380 range and hit this things with a TNT 100 shot it should be oh ****, hold on time
chances are you will be lucky to make 350....
without a verter this thing is gonna be real shaky at stop lights....
I have to agree.
355-360 tops if you have a good tune.
I would suggest you keep you money and have LS1edit done on a dyno instead of sending you computer off for the tune.
These companies are good but cant compete with a person reading and retuning for every extra HP.
A converter will be your best friend.
Although I dont think it is a must, but it is a almost MUST.
I would suggest a 3500 stall with that cam and would suggest you do the verter first.
You will be faster with a verter and stock cam then you will with a cam and stock converter.
BTW throw this post out the window as it is not compairable with what you have.
Eric
it still gives a good baseline number to go by. everyone knows the rwhp difference between the too. the only thing i have thats not compairable to you is in my pants...
399.5 hp
387 TQ
2000 TA
this dyno sheet is before the LS6 intake and injectors
http://community.webshots.com/photo/...85407474sXZenM
