Bolt-on tune Ws6 Dyno numbers
Old Jun 30, 2016 | 08:59 AM
mintws6's Avatar
Talking Bolt-on tune Ws6 Dyno numbers
Took my car to G-Force motorsports yesterday for a dyno tune. I have a 2002 Ws6 30k miles with a K&N FIPK, Texas Speed 1 7/8" long tubes, ORY, new texas speed cat back, new TR55 plugs and MSD wires. Final numbers after tune were 350hp/365tq I'll post picture of the graph later. Quite happy with how she came out.
Old Jun 30, 2016 | 09:04 AM
HCI2000SS's Avatar
Sounds good!
Old Jun 30, 2016 | 09:43 AM
fst100's Avatar
nice. this through an auto or manual?
Old Jun 30, 2016 | 09:49 AM
mintws6's Avatar
Its a M6
Old Jul 8, 2016 | 08:43 AM
mintws6's Avatar
Originally Posted by mintws6
Its a M6
Just got to take it to the track now
Old Jul 9, 2016 | 11:56 AM
assasinator's Avatar
It's only 90 rwhp less than hammers 440 bolt ons
Old Jul 11, 2016 | 07:14 PM
scotty2000ss's Avatar
Not bad OP.
Many more bolt ons to be had.
Old Jul 12, 2016 | 12:01 PM
mintws6's Avatar
Originally Posted by scotty2000ss
Not bad OP.
Yes! Still trying to decide what's going to give me the best gains for the buck going forward... but those 241 heads are just going to limit me I think....
Old Jul 12, 2016 | 01:28 PM
Darth_V8r's Avatar
Moderator
If you're wanting to just stay bolt ons for now, do a light clutch. You'll be surprised how much that wakes the car up. Also gear up your rear axle. Going from 3.42-4.11 is about 20% torque planted to the ground. Also wakes the car right up.
Old Nov 4, 2016 | 11:47 PM
mintws6's Avatar
Smile
Track numbers are in I ran a 12.77 at 109.8 tonight 1.9 60 foot da was 1562 I only got one pass in due to them opening late.... bogged a bit on the launch felt like there was a bit more in her any how let me know what you think I was happy!
Old Nov 4, 2016 | 11:50 PM
mintws6's Avatar
Time slip
Old Nov 5, 2016 | 02:57 PM
SoFla01SSLookinstok's Avatar
Good run!
Old Nov 6, 2016 | 08:10 AM
mintws6's Avatar
Thanks! Going to shoot for a couple tenths better in some cold weather conditions
Old Nov 7, 2016 | 12:16 PM
HioSSilver's Avatar
Someone seems a bit hurt by that. Different dynos....different cars....different mods. Should they dyno the same?
Time slip
There is more in it than that. You shoukd easily be over 110.
Old Nov 7, 2016 | 03:27 PM
mintws6's Avatar
Probably need to spin her up higher, not gonna lie I was shifting @ about 6k plus that soft launch at 3500 kinda made her fall on her face..... Really need to get a tick master cylinder that stocker sucks after the tranny warms up.... unless anyone has some other tips they are much appreciated!!!
Old Nov 7, 2016 | 03:30 PM
HioSSilver's Avatar
It's not a master problem. You need a clutch. Your pressure plate is giving up if 4th is notchy. Especially if you are still on the stock clutch.
Old Nov 7, 2016 | 03:36 PM
mintws6's Avatar
For me its third gear if I spin 2nd up over 6k getiing in to third is sometimes not possible. You think clutch? I have a crappy Luk clutch, supposed to be similar to stock clutch..... any recommendations for decent clutch I wiil be doing H/C/I down the road so I guess I should prepare to handle some decent RWHP. Thanks in advance for sharing the knowledge
Old Nov 7, 2016 | 04:20 PM
HioSSilver's Avatar
Ok 3rd....yup if you're on stock gear still. If you had 4.10 gears it would be 4th. It ends up being time vs rpm related. The longer at high rpm it gives the pressure plate time to give up. The fingers suck in....then the hydraulic release bearing can't throw far enough to release the clutch disc. Same thing used to happen on mechanical clutches back in the day if you turned to high of a rpm. Now it gets blamed on these mysterious hydraulics. Lol.
Rpm related is a dead giveaway the pressure plate is weak......or to weak for the application.
Get something light weight. Don't be scared to drop some decent coin on a good light clutch. It will shift smoother and add performance. Tilton/qtr master/spec/mantic all have nice little mini twin type clutches.
