FMS F13 cam-only dyno results
Old 06-20-2004, 10:22 PM
c5ls1vette's Avatar
What was the air fuel and where was your timing at? The dyno is mainly for tuning purposes. Run the car at the track and go from there. By the way where did everyone get that the humidity was only 10% here in Texas, it is always high here. Today for example it was 93% humidity and today has been one of our cooler days.
Old 06-20-2004, 10:52 PM
Mike K.'s Avatar
hey tally what gears you running?
Old 06-20-2004, 10:53 PM
jlaw's Avatar
He has stock 3.42's. Please stay on topic
edit: not trying to be rude, just want to keep the helpful feedback coming.
Old 06-21-2004, 01:31 AM
slmdLS1's Avatar
jon you're an ***.
just dyno at the Lincoln/Mercury meet on the 17th if there is one. i plan on it.
Old 06-21-2004, 02:36 AM
distortion_69's Avatar
I would run it at the track, or dyno at another location. If its definately low I have to agree with gomer in the plugs/wires/fuel filter/air filter, etc. route. I myself struggled with a low dyno with my old cam only making 355rwhp with a 224. It turned out to be a combination of things from tuning to vacuum leaks to exhaust restriction.
Good Luck,
Josh
Old 06-21-2004, 03:03 AM
Ben R's Avatar
Originally Posted by Country Boy
You have to remember... in Florida, 80+% humidity is the norm here. Its VERY rare to see <80%, plus its summer here. If we had the 10% that Texas has, then we would dyno some badass numbers
Unless you live in Houston, then you can't get away from the 80% Humidity!
Old 06-22-2004, 04:38 AM
1BadAzzWS6's Avatar
With the FM4 cam and completely stock heads I put down 390rwhp and 372rwtq untuned. It was high 90's with a puttload of humidity at the time and that was thru LT's, oryp, and SLP LM. Other mods included plugs/wires/lid. I think the only bolt on mod I don't have is the ASP pulley. In cooler weather with a cutout I'm sure I'd be seeing at least 400rwhp N/A. With the cutout open I'm trapping 115mph N/A.
On the 100 dry shot it put down 452rwtq and 472rwtq on the same day of the dyno.
Old 06-23-2004, 01:32 PM
jlaw's Avatar
Thank you for your useless, off-topic reply.
Old 06-23-2004, 05:49 PM
slmdLS1's Avatar
Originally Posted by 1500Sleeper
jon you're an ***.
Quick Reply: FMS F13 cam-only dyno results
