Boosted LT1
Old Feb 9, 2017 | 09:37 AM
SwampWS6's Avatar
Default Boosted LT1
Nothing special to see here. Car made 563/481 on 8lbs on the dyno. Biggest issue was blowing through the converter. We calculated the slippage and it was roughly 40% based on the tuners observation and me using a converter calculator. Car was on E98 at the time because there wasn't good E85 in the area due to winter blends. Obviously from the vid, there is too much fuel upon decel, having the FPR hooked up correctly probably would've helped. 80ish percent duty cycle with 17* of timing so far. So hopefully I can get these gremlins worked out and have a successful year this year.
Issues to be fixed:
1. Converter
2. Cylinder #4 misfire
3. Boost referenced FPR vacuum line was not connected
4. Plugs gapped too far
5. Developed exhaust leak while on dyno
I am the guy that cares more about an ET than dyno numbers. But who wouldnt want killer dyno numbers?
https://www.youtube.com/watch?v=Kbp6...ature=youtu.be
Old Feb 9, 2017 | 12:09 PM
SoFla01SSLookinstok's Avatar
Cool build man! What are your goals at the track?
Old Feb 9, 2017 | 12:42 PM
SwampWS6's Avatar
I REALLY wanna break 5.99 in the 1/8th mile. But 9 anything I'll be satisfied!
Old Feb 9, 2017 | 10:34 PM
T/A KID's Avatar
If you need any help on that rig (tuning wise) hit me up with a PM....
Old Apr 4, 2017 | 09:04 AM
RealQuick's Avatar
ANy updates?
Old Apr 4, 2017 | 04:17 PM
SwampWS6's Avatar
Well I have new converter and other other issues wrapped up. Car pulls a lot harder and tire breaks loose with ease now. Will be going to track here soon to see what type of data I can get. 2 step and A arms are installed as well. Car is 95% done.
Old Apr 5, 2017 | 05:46 PM
RealQuick's Avatar
Glad to hear!
Old Apr 6, 2017 | 11:06 AM
SwampWS6's Avatar
Going to track this weekend. Lets keep our fingers crossed
 Michael S. Palmer
Old Apr 9, 2017 | 06:56 PM
RealQuick's Avatar
How did you make out?
Old Apr 11, 2017 | 08:50 AM
SwampWS6's Avatar
Im somewhat satisfied. Went 7.04 on the brakes hard shifting at 5500rpm with 84mph trap. Didnt even turn my boost controller on, so this was all on gate pressure which is 8lbs. 1.5 60ft. Not a horrible 60ft but I wanted more
Old Apr 11, 2017 | 09:23 AM
383z's Avatar
I LOVED THAT DYNO PULL!
That LT1 though..... is dreamy.
Old Apr 11, 2017 | 11:06 AM
SwampWS6's Avatar
Thanks man. Wasnt really number hunting, but more concerned with track numbers. Almost sounded like it was gonna blow up. Lol
