Low 408 stroker numbers on the dyno...ideas?
I put together a 406 stroker for a buddy a few years back. It had similar heads and cam to you, but your heads and exhaust are a little better. Through a 4L60 and a 12 bolt it did 497 to the tires. It had a 102 on it as well. Trying to remember but I think that was also a SS3600 car.
yes the heads are small but TQ shouldn’t be down like that
AFR is lean. Do you know what the max timing is? What fuel are you running?
Def look at that AFR. If its properly tuned it could be indicating the fuel pump is failing.
Also, maybe just start the car from cold and check the headers for a cold primary - ie dead cylinder.
Torque converter is a possibility as well, but I deal so little with autos I can not give good advice on that point.
Torque converter is a possibility as well, but I deal so little with autos I can not give good advice on that point.[/QUOTE
Found one plug wire with nice hole burned in it, one with a big crack in it and another with top of boot melted. It's running on all 8, I 'll drive it as soon as pavement dries up.
