Bad dyno tuner?
Old Jun 6, 2018 | 01:25 AM
SRT8.Acelleration's Avatar
I found this and a few others, seems there into import stuff not LS stuff. #19
piette
Real Name: jeff
Member # 5329
Status: Offline
Casino cash: $88900
Like: 0
Liked 0 Times in 0 Posts
Rep Power: Quote:Originally Posted by GreenbayTBSS
Nice. I hear Beyond Redline has an awd dyno. Im not sure about them though after they quoted me 4hours($320) of labor to install a magnaflow catback. Thats crazy
They did the tune on my TBSS. I would not recommend them to tune anything but something with a fartcan on it. They sucked. Luke Stubbs, the owner of Beyond Redline did it himself, and all he kept saying is that LS engines are a really tricky thing to tune. After 3 hours of tuning and over $300 I walked away with about 3 hp more than I went in with and had less torque. They are a joke, don't go there!!!
Im going to be getting a tune done on my CTS-V, it sure as hell wont be them doing it
Jeff
Old Jun 6, 2018 | 01:33 AM
You could try these guys, may help ya out...
https://www.tunedbyfrost.com
Old Jun 6, 2018 | 08:30 AM
NHRAFORMULA00's Avatar
about 12 years ago my car dynoed 430 on a mustang dyno (locked converter ) with the same heads and cam.
Old Jun 6, 2018 | 10:38 AM
Chris25's Avatar
That seems like bolt on a4 numbers. I would definitely find another tuner, also wouldn't hurt to invest in HP tuners and a wideband so you have the ability to do some logging.
Old Jun 6, 2018 | 10:40 AM
98CayenneT/A's Avatar
I would run it at the track and see what it traps before I did anything else.
It's a stalled auto. Your dyno numbers are going to suck unless you lock the converter.
My buddies setup: DYNOED 357 WHP
Full exhaust, tick SNS 3, 243 heads, YANK PT 4000.
LS6 Intake. Trapped 118 mph
My setup: 396 whp with setup in my sig.
Trapped 122 mph with lots of tranny issues. (cracked input drum)
Both cars are close to full weight also.
Both cars would make well over 400 whp through a 6 speed.
Old Jun 6, 2018 | 01:44 PM
codyvette's Avatar
A similar setup we did with with 243's made 409. A4 car as well. Pat G tuned on there md250.
Old Jun 6, 2018 | 02:37 PM
Chris25's Avatar
Originally Posted by Road_House
runs ok, when idling it gets down to about 600rpm. When I gassed on it, it redlined to 6500rpm and stuck there for a second or two, doesn't seem to shift when it should be under wot
Did the tuner street tune after the dyno tune?
Old Jun 6, 2018 | 02:41 PM
codyvette's Avatar
As far as unlocked, my heads cam LS1 made 450 through a 4500 stall glide.
Old Jun 6, 2018 | 04:16 PM
speedyjim's Avatar
Default Bad dyno tuner?
Hey guys,
This is Jim, counter guy at Beyond Redline. I have read your comments and thoughts, and thought I'd join the conversation. I'll start by saying that I myself don't do any tuning, but I have owned several built LS cars so I do have some personal experience with them.
I knew it had a pretty loose converter, but I too was surprised with the low numbers that the Firebird made. We started the dyno pulls where we did because of just how loose the converter is. Since there isn't a converter builder alive who recommends locking anything but a triple disk converter on a dyno, we didn't lock up the converter.
Beyond Redline has tuned hundreds of LS powered cars, some making more power than owners expected, some less. We tune cars so that they will live, not blow up the first time they see a tank full of subpar gasoline.
As you can tell from the A/F ratio, fuel is well within acceptable levels. We started with minimal ignition timing and added more in until the car stopped making power, then backed up just a bit. As you all know there are tons of variables between brands of dynos, and every vehicle will make different horsepower, even with the same parts.
I have been in contact with Road_House and we've discussed the concerns he's expressed on here and also some minor cold start issues and he'll be bringing the car back for a little tweaking soon.
Old Jun 6, 2018 | 04:36 PM
I agree and was not trying to imply to lock a single disc converter. Was just saying with a loose unlocked converter I personally would be more concerned about trap speeds than dyno numbers unless I had a triple disc that I could safely lock
Old Jun 6, 2018 | 04:40 PM
speedyjim's Avatar
Couldn't agree more!
Old Jun 6, 2018 | 05:57 PM
  #32
Hey guys,
Looks like they are gonna stand behind there work and help him out, can't ask for much more then that I guess. But yes, if the converter is not locked the power numbers are going to be low, doesn't mean it's not going to perform at the track.
Old Jun 6, 2018 | 09:05 PM
  #33
Game ova's Avatar
I just went through this last week, put the car on the rollers.... and it put down weak numbers, but runs decent at the track. As a few others have said already, take the car to the track.... let the track do the talking.
Old Jun 12, 2018 | 08:08 AM
  #34
Marc 85Z28's Avatar
ANY competent tuner that's familiar with the platform would look at the parts in the build and the fucked up graph (look at the early peaks and lazy curves) and realize there's a problem and have a pretty good suggestion as to the culprit.
Old Jun 15, 2018 | 02:49 PM
  #35
Road_House's Avatar
Not to my knowledge. Sounds like just a quick test drive after and that was it.
Old Jun 15, 2018 | 02:51 PM
  #36
Road_House's Avatar
tuner said everything is good. If anything could be wrong he wouldn't know. He said it could be anything from push rods, rocker arms to the torque converter and everything in between.
Old Jun 15, 2018 | 02:52 PM
  #37
Game ova's Avatar
This made me spit out my beer! ROFL.
Old Jun 17, 2018 | 09:00 AM
  #38
Chris25's Avatar
Usually a street tune after the dyno is needed to iron out some of the drive ability issues that may come up. What did the car run at the track.
Old Jun 18, 2018 | 09:49 AM
  #39
NicD's Avatar
7 Second Club
Tell me what looks fucked up in that graph? You said early peaks and lazy curves but seeing as how the horsepower peaks around 6200 rpm and peak torque is around 5000 rpms I don't see anything indicating that cam that is off a tooth or anything like that. It peaks in all of the right areas and the curve looks appropriate for an unlocked dyno pull, the power is a bit low but that could be a bunch of different things non of which could be the tuners fault. Making horsepower is easy, add timing until it stops making power and make sure your a/f is correct and what else can the tuner do to make power? The tuner himself came on here and backed that up.
Old Jun 18, 2018 | 09:52 AM
  #40
NicD's Avatar
7 Second Club
If the tuner said it looks good then it could be anything like he said. A tuner can't make horsepower come out of nowhere, and yes it could be the wrong pushrod length or something being wrong with the converter, transmission, etc. I've been in that same situation many times where the customer is looking at me like what's wrong, as a tuner you can adjust timing and fuel to make power and THATS IT. If you have the fueling correct and it's taking as much timing as it will take then you can't do anything else and there is something else going on.
