Highest rwhp from NA fbody???
Old Dec 6, 2018 | 09:14 PM
big hammer's Avatar
I think I seen damn near 600 on a short stroke big bore. Basically a 4.125 x 3.27. Spun to the moon and back
yup 594 rwhp with 346 CI through a stalled th400. Would be well over 600 with a t56.
Old Dec 6, 2018 | 09:52 PM
HioSSilver's Avatar
Ima give a mild build 346 a whirl after this water in the oil bad luck with the ls7. I don't have the budget for a set of these mamo heads but i still think somewhere around 550whp can be done. After all the bolt on ls6 did 451whp so a decent compression bump, a Darth spec'd cam and some ported 243s should get 100hp i think.
Old Dec 6, 2018 | 10:05 PM
NAVYBLUE210's Avatar
From: Coast of San Mateo County Between Pacifica & HMB
Yes. The first post in that ghost hawk build thread is where I ended up. I kept it updated with everything. But its worth reading the whole thread, because beyond the mods, I posted every mistake I made. There are a lot of nuggets in that thread beyond the list of parts. I do think there may have been another 20 or so HP, but I was not going to get it. I was losing compression and on disassembly I found hot spots on the bearings. My rings were not badly worn but they had no spring in them anymore.
Be cool if you did beat it. Mixed emotions for me though. Lol
Honest question -- you think the mast small bores might beat the Mamo 220? I kind of doubt it myself.
That thing really was a badass 346.
Jake,
You absolutely had the best performing Streetable SBE 346" that I have seen on Tech
in the over 12 years that I have been following. The "easiest" way LOL!
to surpass that would be to duplicate (You so generously provided the full details)
add .5 Compression, .020" lift, +3-4* of cam durations with the correct events.
Not to original however.
I believe the MMS 220s are the best Heads for a 3.9" Bore, especiall factoring the
port & valve sizes, compared to the Mast Small Bore LS3 which are 240 CCs as
you know. However I believe the FAST LS3 W/ Mid-Length Runners are Ideal to
provide peak HP between 7000-7500 RPM, and while you definitively proved the
MSD peaked & carried beyound the FAST 102 Cathedral. I Believe the MID-Length
peaks and carries beyound the MSD, Unfortunately we can't compare with the
same Heads.
My initial post was in no way ment to disparage your results.
It was just a different idea on how to possibly exceed 550 RWHP with a
"streetable" SBE 346" and a extreme budget.
Old Dec 6, 2018 | 10:19 PM
Darth_V8r's Avatar
Moderator
Oh that's a great point about the intake options. And you're right. Go to 12.x compression, add cam, should beat it. Would require flycut. I would not push it any tighter than where I was on PTV.
I didn't take any offense or anything. I was honestly just asking your opinion
Old Dec 19, 2018 | 09:37 AM
Public Enemy's Avatar
Originally Posted by bnastystuntz
i bet u could get upper 500 dependin on setup.... bump the compression ration 13:1 Good set of heads ...How u thinK TEXAS SPEED got that stock bottom end record .
You will be surprised how many stock 346ci have achieved lower than 9.6x in stock bottom ls1.. not everyone posts this in the forums. as a matter of fact, some of them dont even have that high of a compression and running ported 243's.
The trick is to invest in making the vehicle extremely light weight... one of the fbodies i am talking about showed up lower 2400lbs and a fox body with a stock cube na ls1 ran 9.3 with 2150lbs with some patriot 243's, vic jr intake a hyd roller cam...
Old Dec 29, 2018 | 02:01 AM
bnastystuntz's Avatar
id rather less weight myself. my ws6 is heavy compared to the Camaro. i think a 200+ lbs difference. mine weighs like 3500 w/o me in it and my buddies Camaro weighs like 3300 and he basically full weight minus spare
Old Jan 3, 2019 | 11:50 AM
ddnspider's Avatar
Real street car i'm sure
Old Jan 3, 2019 | 05:10 PM
Lol no way street car.. But neither was the tsp race car as well..
Old Jan 3, 2019 | 05:33 PM
ddnspider's Avatar
Yeah I know just kidding .
Old Jan 21, 2023 | 05:14 PM
519camarobrad's Avatar
Been a long time since I made my post but here's the final update on my build, I managed to squeeze out 502whp and 428tq.
Old Jan 25, 2023 | 07:33 AM
jasons69chevelle's Avatar
Why is the HP and torque not crossing at 5250?
Old Jan 25, 2023 | 11:17 AM
  #32
spanks13's Avatar
Because the scales are different on the graph for hp and torque. Torque and hp are the same at 5252 ~ 428hp/tq.
Old Jan 25, 2023 | 06:17 PM
  #33
HioSSilver's Avatar
what's the set up on that??
Old Jan 25, 2023 | 06:40 PM
  #34
BTR stage 4 cam
Trick flow 215 CNC heads
Msd atomic Airforce
nick Williams 102
Johnson 2110 lifters
Carillo Pistons
Scat rods
Yella terra 1.7
ferrea valves
Meziere ewp
100 maf
SSRA intake
SE 1 7/8 LT
SE 3" true dual
Old Feb 2, 2023 | 04:33 PM
  #35
HioSSilver's Avatar
5.7??
Old Feb 2, 2023 | 04:53 PM
  #36
Yes 5.7
Old Apr 19, 2023 | 08:58 AM
  #37
02EBC5Z06's Avatar
I thought the goal was with a stock bottom end ls1?
Old Oct 3, 2023 | 08:29 PM
  #38
asthmamax11's Avatar
Just wondering what people think or know the highest rwhp from a stock 346 N/A build in an fbody is?? I know all the highest numbers like 530-540 were in a c5. But what about in a 4th gen fbody?
I heard Hiosilver did some big things in his stock LS6 powered Fbody
Old Oct 9, 2023 | 03:29 PM
  #39
Deleted
Old Oct 16, 2023 | 04:41 AM
  #40
Jimbo1367's Avatar
Didn’t Patrick G get over 500RWHP in his F-body over a decade ago?
