are these numbers reasonable
Then it would have to be something wrong in the valvetrain.
I had an issue once.
I was running a Lingenfelter 229/242 114 LSA camshaft once when my engine was a 6.0.
It made very good power however after 5000rpm the power just died off when this camshaft should have pulled to 6800rpm+
I found out later, those lobes on the Lingenfelters camshaft are Comp LSK which are brutal on the valve train and you need very strong springs to control them.
I just had average dual valve springs that were rated to .650 lift.
I also believe my valve train geometry was not right either but I could not confirm this. Maybe even the pushrods were not strong enough or the preload wans't right. Maybe even a combination of both.
I was dealing with a moron who was in the middle back then who I no longer use anymore.
He ended up not being able to sell his business because of his bad reputation, and then he burnt it down and made it look like it was an electrical fault with the wiring even though the building was only 5 years old.
Will keep updates coming as i check things out.
Check spring install install heights etc too.
Not really a fan of single pattern camshafts due to the fact that the intake and exhaust do not flow equally.
Even high end cathedral heads have a 4-6 degree splits.
A 228/236 113+2 would work better.
If you had the same intake and exhaust flow a single pattern camshaft would work best for sure.
No head cylinder in the LS world flows like this.
Ls1/LS2 cathedrals like a 6-10 degree split
LS3/LS7 like a 12-17 degree split
I strongly recommend the 227/234 113 LSA +2 or for something more aggressive go with the stage 3 which is a 231/242 112 LSA +2
Both of these will work great.
The 228r cam is also fine for what you are doing.. it makes plenty of power no need to go with something different there.
The rest of the valvetrain would only be an issue if something was improperly installed or if the pushrods were too long.
Stay the course, keep the cam, and diagnose the issues.
Otherwise it will be something else.
Cam choice from Tooley as mentioned earlier is still better.
Also the tune does have a small problem, but i have no idea why i have data logged and never seen the car knock, I'm wondering if my sensors even work, but we are tryin to figure out why the graph did dip like that. i will keep everyone updated
