are these numbers reasonable
It peaks way too early and falls off a cliff.
Darth is right.
Camshaft was not installed correctly and I also think you have some serious valvetrain issues.
If I had a curve like that I would be checking pre load, pushrods, checking the valve springs etc.
Something is not right.
That is one of the most unusual dyno curves I have ever seen.
Darth is right.
When you say the cam is not installed correctly do you mean it is not in time?
I will check my pre load today when i get home from work.
any other suggestions to check while i'm in the engine?
I want to be very clear. That super high torque spike at 3500 that tails off with rpm is the converter flashing. You get torque multiplication by design. It was the 5400 rpm peak with fast fall off that made me suspect the cam.
I had a motor that did that same thing. Hit peak at 5600 and fell hard. The cam was off nine degrees.
Darth is right.
I would certainly check how the camshaft is installed first then check the rest.
The converter locked would be worth a shot too.
I will be checking the valve train today after work.
Then it would have to be something wrong in the valvetrain.
I had an issue once.
I was running a Lingenfelter 229/242 114 LSA camshaft once when my engine was a 6.0.
It made very good power however after 5000rpm the power just died off when this camshaft should have pulled to 6800rpm+
I found out later, those lobes on the Lingenfelters camshaft are Comp LSK which are brutal on the valve train and you need very strong springs to control them.
I just had average dual valve springs that were rated to .650 lift.
I also believe my valve train geometry was not right either but I could not confirm this. Maybe even the pushrods were not strong enough or the preload wans't right. Maybe even a combination of both.
I was dealing with a moron who was in the middle back then who I no longer use anymore.
He ended up not being able to sell his business because of his bad reputation, and then he burnt it down and made it look like it was an electrical fault with the wiring even though the building was only 5 years old.
