Car cut out on dyno...need help diagnosing the problem
Here are my current mods during the dyno:
1999 Z28
Jet Hot LT's w/ true duals
LS6 intake
Jantzer Throttle body
TSP Air Lid
MSD 8.5mm wires
NGK TR55 plugs
After the dyno I was told by the dyno man to check plugs and wires, because more than likely that was the problem. I pulled all my plug wires and checked them with an ohm meter and they all checked out fine. I also pulled all the spark plugs and they all looked fine and were gapped exactly where they should be. (right around .055)
The only thing left that I can see causing the issue would be coil packs, battery, alternator, wiring. Any ideas on what could be the problem? This cutting out is unnoticed by me, and apparently the only way I will know if it is gone is to put it on the dyno. Car seems to idle smooth. Only problem I know of is tonight when I drove home my buddy said all my lights were flickering on my car (headlights, taillights, and I even noticed my dash lighting was flickering). Any chance this could be related and what needs to be checked/replaced? Any ideas would be greatly appreciated, because I really dont want to spend more time at the dyno only to find out my problem still exists.
