Low numbers for an LS6?
LS6 short block
Tick perform mace street heat 1 cam 225/228 | .615”/.595” | LSA112+3
Total Engine Air flow 243 with Stage 2 Porting stock compression
Fast 92
Fast TB
Upgraded injectors I forget the states
Long tube headers
UD pulley
3" exhaust
Ford 9 with 3:70 Gears
4L60E 3000 stall
After 2 pulls my numbers were 407whp 376tq
What do you guys think?
However, I would have used the FAST 102mm.
It's a much better piece than the 92mm.
Camshaft is good and mild so I see so issue with that.
If you fit a larger camshaft don't go too big or else driveability will suffer too much if it's primarily a street vehicle.
In my testing there is little to no difference from the fast 90 to the fast 102 at that power level. Both need porting to perform well.
Idk how much a auto soaks up power but my bolt on ls6 ended up at 451whp 423wtq and that was through a 9" and a m6. Various combinations over the years helped get it there. Lowest it ever dyno'd was 399 but that was on the stock ls1 tune.
