Engine Dyno....347 Compression engine w/ MMS 220 cathedral heads
The following users liked this post:
Elic (07-16-2020)
We used both Sunoco E85R and Sunoco 112
Elic (07-17-2020)
Shouldn't one be concerned about the oil pressure dropping as RPM's are going up? This is one bad *** little setup.
I also had AFR205's on a SBE LS1 in 2004 and milled them to make about 10.7:1 with LS6 intake/stock TB, 233/239 cam, long tubes, FMS 30# injectors, M6 and it made 440rwhp/385rwtq (DynoJet). 100mph in the 1/4 and 129mph best 1/4 at 500-1000DA and 2900lbs with driver.
Tony, how close to these msd results do you feel you could come to these but with a hyd cam setup. I have prc 225 60cc as cast heads , and off shelf cam now @463whp. Was thinking of different cam and fly cutting and these results really impress.
