dyno numbers ????
how can i look at the final numbers and then know kinda what it would make in real world situations.
so for example if he makes a pull and gets 500 hp and 550 trq what would it be oh i guess in my set up which is
05 blazer with belt,ac,then thru the t56 transmission,thru the driveshaft into the gears and axles then finally to the tires.
google wouldnt cooperate with me on this lol.
reason being all these video's of his he's getting big numbers = im bummed.
i have a L96 with ls3 stage 1 cam,ls3 intake,and headers and yadda yadda and im only getting 400 hp to the tires & 380 trq to the tires.and everyones like that seems low and it doesnt really run too good to me either,im not impressed so if your bored and know this which im sure lots do holler back ok,cool
If your car doesn't run well, that has zero to do with parasitic accessory loss or drivetrain loss.
Dyno's are great for base lines and tuning a given car or truck etc. Dyno's engine & chassis aren't so great for comparing to each other due to different measuring criteria, philosophy of design, different test procedures and so on.
~ 380whp to 395whp on a DynoJet
~410wtq to 425wtq DynoJet
Weight of tires and wheels can shift numbers by 5 hp. Disc brakes dragging on the rear can eat 10 hp. Plus other factors. Always a grain of salt wirh dyno numbers.
What was it dyno'd on?
Mustang's often read lower than DynoJet's etc
He was just explaining how Holdener dynos his engines and why he does it that way.
He is getting a pure, raw number with NO parasitic loss of any kind.
That way any changes to the engine are reflected in the power numbers without anything to deflect them.
1. Did anybody do any work on your heads?
2. What’s your compression ratio?
3. What are your cam specs? Saying that you have a “LS3 Stage-1 cam” is almost meaningless since EVERY cam maker’s Stage-1, 2, 3, 4, etc cams are different. NOTE: If you don’t know the specs, do you know whose cam it is?
4. Are you running stock exhaust manifolds or headers? If headers, what kind/size? And what's the specs on your exhaust?
5. What gears are you running…..and what diameter are your tires?
6. Real silly question, but.....was your truck tuned for your current setup?
All of these factors can affect your HP to the wheels.
KW
