415 LS3 dyno numbers
This is a race engine that's going in my tube chassis big tire bracket car. It has 13.75 compression and a CID 4500 intake. It made 683 hp @7000 and 581 tq @5300. the weather was 84 temp 77 hum 29.89 baro and a DA of 2068 ft. I had an issue with my vac pump, so when that is fixed it should make a little more.
Randy
Randy
60ft 1.190
330ft 3.556
660ft 5.551 @ 124.79 35 degs of timing
This is on 110 race gas and what I found interesting was on the dyno 25 degs of ignition timing is all it liked, but it only ran a 5.67 @121.5.
Increaseing the timing to 35 degs I picked up .12 in et and over 3 mph. who says LS3's don't like timing.
60ft 1.190
330ft 3.556
What does your car weigh?
I experimented with timing also and found my LS3 engine liked 29 total. Have you verified TDC on the balancer with an indexed pointer and a timing light?
I find it interesting so many run low ignition timing on the LS3, claiming efficient chambers etc. for their reasoning. I see a lot of higher end build SBC and BBC with 9*, 10*, 11*, 12* heads and very small, efficient modern day chambers that look very similar to the 'trick of the week' CNC LS3/LS7 chamber and they make the best power at 30* plus. Go figure.
35 degrees I've never heard of, especially on gas. I agree maybe TDC marking is off. Regardless, you now know what the engine likes so no real need to worry about it lol.
I started at 32, went up 2 every pass, and at 34* I got my best ET, 36* got my best MPH, and 38* it slowed down a lot. I stuck with 35*
LY6 clone, 10.8:1, cammed
