expected rwhp gains
Old Aug 2, 2004 | 06:50 PM
black99ssm6's Avatar
Default expected rwhp gains
I've got a 99 ss m6 and i'm about to order the tsp true duals, flowtech lt's, and a set of high flow cats. the above mods plus my current slp lid, K&n, slp cold air induction, smooth bellows, slp 85mm mass air sensor, pro 5.0, spec stage 2, 02 slave clynder.
Old Aug 2, 2004 | 09:07 PM
Gloveperson's Avatar
I would say around 340-350 with a tune, your MAF may be making your A/F ratio a bit off.
-Todd
Old Aug 2, 2004 | 09:30 PM
I was thinking around that range but wasn't really sure.
Thanks for the input
Old Aug 2, 2004 | 10:38 PM
zchgla's Avatar
so you would guess about the same for me?
98 z28 m6
2.5 inch true duals with sweet-thunder mufflers
lid
Old Aug 2, 2004 | 10:45 PM
Well, yes if you had LT's.
Those are good for about 20 RWHP.
Old Aug 2, 2004 | 11:21 PM
zchgla's Avatar
98 z28 m6
lid
my bad, and pacesetter longtubes.
im really hoping for atleast 320 with everything on
Old Aug 3, 2004 | 01:10 AM
mooleyz28's Avatar
im hoping for 320 as well.
Old Aug 3, 2004 | 09:04 AM
Well like, most cars (especially M6's) do get around 340-350 with full exhaust and a lid, ported TB and some free mods. Your true duels probably add more than my magnaflow cat-back and any cat-back for that matter so I am assuming you are both higher than 320.
-Todd
Old Aug 3, 2004 | 03:51 PM
slik98z's Avatar
the td's will push the power up the power band further...you will lose some torque...but you'l more than make up for it in the top end.
if you would like to be closer to 350 rwhp with the m6, get dyno tuned. that is usually good for around another 10 rwhp
Old Aug 3, 2004 | 05:44 PM
davered00ss's Avatar
Moderator
Tuned you should gain 25 rwhp with the Lt's & duals. a 98 or 99 with tose mods should be about 320rwhp.
Old Aug 6, 2004 | 03:27 PM
Raben's Avatar
I would say you should already be at 320rwhp. I have an auto with the SLP lid, K & N filter, SLP 85mm MAF, SLP Smooth bellows, ASP underdrive pulley, Hooker cat-back, Flow-tech Exhaust Cut-out, 3500 stall converter, 3.73 gears, B & M tranny cooler, LS1 Edit dyno tuned. And I am between 315 and 320 depending on weather ofcourse on a mustang dyno.
And it is also a 99 model still with the LS1 intake and stock manifolds.
You being in a M6, with just the basic bolt ons you should be around 320 if not a hair over. I dynoed bone stock 316 at the wheels. The stall and gear combo knocked me down to 290 though LS1 edit gained me back to 308.
I haven't had it dynoed since I installed the flowtech cutout and underdrive pulley but from other peoples gains and my improvement at the track (.25 increase with both mods together) I think I'm at 320
Once you install the LT's you should be 340 easily. And with a good tune, 350 or even 360 is attainable. Throw in a LS6 intake for good measure as they claim from these boards at least 10hp and you should exceed that goal easily.
I'm going the same route with my A4. . .and later shoot for 400 at the wheels going cam only or heads/cam combo.
Good luck and post results after your LT's as I am thinking about the flowtech headers too.
Old Aug 6, 2004 | 03:45 PM
zchgla's Avatar
i dynoed at 306/318. i think thats about right, 320 and i would have somewhat of a freak
Old Aug 7, 2004 | 05:24 PM
lsx24's Avatar
That sounds about right. When my buddy has his true duals before and after dynoed, they send a print out of pwr & tq every 100 rpm. I didn't bother look at any of the numbers but TDs will add power at almost every setup level. The graph says it all.
