Highest RWHP #'s on cam only LS1???
Originally Posted by WAHUSKER
I think I have one of the highest Hot Cam dyno queens - 391rwhp & 371rwtq SAE. Without locking the converter. Every car I've seen over 400rwhp had heads or a power adder.
I am on stock heads
Dyno #'s before ls6 intake swap
392RWHP 389RWTQ. Stock heads and couple bolt ons.....
Greg
Originally Posted by Clipper
Cant wait to see the numbers!
Here's a video of it idling.
Here's a video of it making a pull.
Specs on this cam for now will remain unreleased until later. But this cam DEFINITELY will fit a stock motor w/ stock heads, and should also clear mild milling... It is smaller than a Trex cam, but has much more p-v. Picked up power everywhere above 2700 rpm.
Chuck
I have been in this HPE car and it is sick. If you are in Houston or in driving distance Chuck (the Owner) and his crew do some of the best work I have ever seen and I have seen alot of guys in Texas try and do what they do. From the fisrt meting to the drive out you will be completely satisfied with there work and there professionalism. So if you are in Houston or are williong to order online these guys are first rate and will not let you down.
Originally Posted by Chuck@HPE
It just put down 422 and 384 ft lbs of torque. HP peak was at about 6400, rev limiter is set at 6800, and 29 degree's of timing. Peak torque was at 4900. This was on a 99 model SS Camaro w/ a bone stock motor.....
Chuck
Chuck
Originally Posted by 1SLO-LS1
I am on stock heads
Greg
Greg
#32
Damn, that is amazing on that motor (99 LS1)! Will the cam be streetable? Even for us A4 guys? When you gonna start selling them?
We are selling them now, and they will be ready to ship in about 2 weeks...
Thanks,
Chuck
#33
Just dynoed our '01 Z06 tonight with the T-Rex. Pretty impressive so far.It has the stock H-pipe with TPIS headers and off-roads, Borla Stinger and stock unported TB. It made 449rwhp/401rwtq.
In comparison, I had the Thunder 236/230 cam in it before and it also made good numbers....421rwhp/380rwtq.
I'm going to try the 90mm TB with the 90mm LSX Intake if FAST ever releases the TB for the C5's!
#34
02 firehawk just re-dynoed with some tuning
i have the video if anyone is interested.
as stated before this is g5x3, stock 10 bolt w/ 4.10's electric water pump qtp headers/cutouts heads never been off the car, stock ls6 intake, stock unported tb, stock blackwing lid, asp underdrive pulley, stock firehawk wheels, 275 bfg drag radials
#35
#37
Originally Posted by ChevyWeatherman
My car made 412/384 with just a 231/237 on Speed Inc.'s dyno, no tricks. I think I could hop it up to 420+ with some more timing and other "stuff".
If you put the stock maf back on you would run better and make more power.
#39
master of the "jack"stand
