TSP ported TB
If one of our sponsors will send me a Ported TB I will get a before and after Dyno run. All they need to pay for is the dyno pull and tune ($150) and then if it makes more than 5 hp I'll pay for the Ported TB, if not, then I'll send back the Ported TB. ANY TAKERS???? I'll also post all the numbers on the board if it makes good power, otherwise, I'll keep it quiet. ;-)
I'm a PROFESSIONALLY REGISTERED Engineer. I'm good with numbers AND letters.
Have a nice day!
Drew when your a/f changed, what was different about the dyno pulls? Different dyno?, etc.
2/20/04 dyno - 344.3rwhp 353.6rwtq (pre TB) 12.6-12.8 a/f
(tb installed somewhere in this space of time)
5/5/04 dyno - 1st pull - 347.4rwhp 362.5 rwtq a/f 13.4 (pinging out at 5400rpm instantly dropping 20rwhp to 6k)
We messed with the fuel in ls1edit... adding in some places and yada yada and finally found something that worked perfectly.
6th pull- 349.3rwhp 362.8rwtq a/f 12.8.
All Dyno pulls done on the same dyno (Dynotex, San Antonio Texas)
You said it yourself, fuel trims wont be changed, but you will be getting more air in the motor (if you didn't the TB wouldn't be worth power). So it makes logical sense that a better flowing TB will lean out the car some.
thats why you tune...
