Are these Dyno #'s good??
thanks
mike
That is alot of money spent for not very much gain... but to each his own. They aren't horrible but for stage 2 Ls6 heads that is a bit low.
mike, your numbers are fine and right in line with everyone else who has PP heads and a 224 cam. also keep in mind your through a 12 bolt and 3.73's.
mike
419 with full belt, 12 botl rear and 4.10 gears. Cam is a 234 or something similar with 600/610 lift, on a 111
His powerband is NOT peaky. It is above 400rwhp all through his shift point.
Made 404 rwtq also.
mike
Its a "Ron Jeremy" Cam.. ~236/239 .600/.610 111lsa.. And yes, the cam has alot more duration than this guy, so this is an apples and oranges comparison..
Numbers look decent to me. FWIW: My car made 372rwhp with xe-r 224, a 12 bolt, pacesetter headers, and ls1 intake.. So maybe they aren't the STOUTEST dyno numbers I've ever seen.. but run it at the track and see how it does.. Thats what counts. Dyno probably not quite as peaky as my cam only setup either.. Although my dyno looks pretty damn nice.
Good Luck,
Josh
