New dyno on spray
Old Sep 2, 2004 | 07:55 PM
z289899's Avatar
Default New dyno on spray
Well just got the car dynoed on the spray for the first time. Used a 59 jet. I guess around 135 shot? Shooting through the MAF
N/A numbers were 330/360
Shot the spray at 3k, hp had a nice climb through 4700 where it peaked at 410hp.
Tq on the other hand skyrocketed to a nice 525 and then gradually dropped to around 400 around 5300rpms.
N/A A/F was 13.0 the entire run, picture perfect. On the spray it started getting a little rich, it was a gradual increase. Started about 12.7 as soon as he hit the spray then started going to 12.3, 12.0, 11.7, 11.3, and hit 11.0 at one point. Then started flattening out again toward the last little bit of the run.
Is this normal? I haven't seen a whole lot of dyno sheets but that just seems a little odd to me. Also it wasn't a very smooth graph with the spray, it jumped around a lot more than N/A. I think some of this had to do with the lack of air pressure in the tires. Around 14-16psi I have to run to keep the tires planted. And I still have tr55 plugs with N/A gap on them. Will the plugs help out a little?
I'll try to get the sheet on a scanner in a little while to see if that helps at all.
Thanks,
Nick
Old Sep 2, 2004 | 08:29 PM
oOoLy's Avatar
Nice numbers
Old Sep 2, 2004 | 09:57 PM
z289899's Avatar
can anyone resize this file for me? it's to big to put on here.
Old Sep 2, 2004 | 10:26 PM
NOSjohn's Avatar
Restricted User
Send it over, i'll resize it. jcofolla@twcny.rr.com ...uh 330hp to 410hp isn't a 135 shot.
Old Sep 4, 2004 | 11:59 AM
z289899's Avatar
Yeah, I know it. I believe a 62 is a 150 shot though right? So a 59 I am guessing is "supposed" to be around a 135. I'm not at home right now but I'll try to send it tomorrow when I get back.
Thanks.
Old Sep 4, 2004 | 01:28 PM
Beast96Z's Avatar
Isn't spraying through the MAF the getto way of having your fuels system add fuel? As the MAF grows colder from the continuous spray, it should richin the mixture, thus explaining your A/F. I used to have a gimp kit like this on my 95 mustang. Only problem was is that mustang MAF's couldn't take the cold from the spray, so it shut the motor down. Seemed to work fine on my buddies formula though.:think:
Old Sep 6, 2004 | 09:06 AM
z289899's Avatar
Here's the graph, I think it should work right now. Found an image resizer on another board.
I'm not spraying directly through the MAF, it is pointing forward in the air lid, then being pretty much sucked up through the MAF. I've seen quite a few cars with a dry shot set up this way with no problems. THe problem was when people had it spraying directly on the MAF, pretty much freezing the sensor.
Oh yeah, it got a little wet so there are a few spots where it looks a little blurry. Sorry.
Old Sep 8, 2004 | 03:08 PM
Benjamin Russick's Avatar
Nick,
That dyno sheet looks a little strange... Stop by and see me at work when you have a chance. Laters! Ben
Old Sep 8, 2004 | 03:21 PM
TD's z's Avatar
Needs plugs, and also how are you pulling timing? I hope your running no more than 22 on the spray. Looks like a 125 shot to me by your gains through the middle of the curve.
Old Sep 8, 2004 | 04:24 PM
z289899's Avatar
No tuning has been done to my car at all. Timing is all stock, fuel system is stock, just a bolt on dry kit. Nothing special. That's why it seems so weird. There isn't much that could really go wrong with the kit.
Ben I'll probably stop down next week if I get a chance after this whole wisdom teeth crap is done with.
Later,
Nick
Old Sep 8, 2004 | 10:13 PM
LASTLS1's Avatar
6 Second Club Moderator
Why 22 on spray? With a 125 shot? I ran 150 with 28 deg! No problems. I see no need to pull timing with that small of a shot, unless your running really bad gas. MY .02
Old Sep 11, 2004 | 08:52 AM
z289899's Avatar
Nope, gas is good, could probably use a small amount of 100 or 104, but nothing that is going to affect it that much. As for timing. With all of these bolt on dry kits I've never seen one that comes with a device for pulling timing at all. Just spraying it through the MAF. Computer takes care of the rest!
