Speed Inc.-Single Turbo-348ci -844rwhp 813rwtq-stock pcm
I thought you couldn't sump the stock plastic gas tanks on 99+ F-body's....or are you using a metal tanK???? Why have both fuel pumps external as opposed to having one intank and one external? Why not a big single if everything is outside of tank? Thanks...
SDB
SDB
SDB
SDB
Also if a pump goes **** up wouldnt you rather just unbolt it instead of dropping the tank?
Originally Posted by Chris ARE 385
They are running them in parallel versus serial. Greatly improves flow.
Thanks
SDB
Yes on the plastic tank. As we have shown you do not need alot of cubic inches to make great power. Our C5R Block 427 setup with a GT88 (midframe) setup will be done when we finalize the FAST setup.
How are you using those types of fittings on the stock plastic tank with no leaks? that is great! Do you sell the fittings to do this? i have a single intank walboro and a boost-a-pump, which is fine for now, but I would like a big single external later on...
SDB
SDB
What was the CR? Seems like you could run a lot more than 10psi on pump gas with a lowered CR, but then I guess its already making enough power for the street huh?
