Fast 90mm dyno results
Old Dec 4, 2004 | 11:30 AM
David Gordon's Avatar
Default Fast 90mm dyno results
I want to post up the before and after numbers from my intake and 30# injectors.
old numbers 484 and 466
new number 485 and 448
This was done with the addition of the Fast intake and TPIS throttlebody. I did also install 3.90 gears between as well. We added the 30# injectors hoping we would need them as we were hoping to have 500rwhp but we were a little disapointed, i was more disapointed in the loss of torque.
Anybody have any ideas?
Old Dec 4, 2004 | 11:46 AM
Mooobunnny's Avatar
What intake and TB did you have on it before?
Old Dec 4, 2004 | 11:48 AM
LS6 and a ported stock throttlebody.
Old Dec 4, 2004 | 11:53 AM
Country Boy's Avatar
Senior Member
Tune?
Old Dec 4, 2004 | 12:04 PM
yes, both were tuned #s
Old Dec 4, 2004 | 01:04 PM
RX-Ben's Avatar
What was the injector duty cycle?
Old Dec 4, 2004 | 01:53 PM
Senior Member
Also, are they the red top 30#rs (Fords) or just a 30# injector at our fuel pressure?
Old Dec 4, 2004 | 02:12 PM
LSs1Power's Avatar
Oh i would be pissed off if i got your results. It seems like the LS6 and stock TB's are doing fine. I remember reading somewhere a guy losing power from a LS2 intank manifold too.
Old Dec 4, 2004 | 02:22 PM
Beast96Z's Avatar
Something is bound to be wrong somwhere. Even if you didn't gain hp, you should have picked up TQ. Did you port match the intake to the heads? I know when I set the lower portion of my intake on my heads, they didn't match up very well. I port matched it and removed th elip that sticks out. Power on a stroker motor should show a nice gain.
Old Dec 4, 2004 | 07:15 PM
I thought something is wrong also they tuned on it and that was the best it got. Like I said earlier we added the 3.90s but I cant imagine it robbing that much power. We are open to any helpful hints on where the torque went.
Old Dec 4, 2004 | 07:27 PM
CamaroSS1618's Avatar
I lost about 13 rwhp with my 4.10 gears when I had the stock 10 bolt. If you have updated to a 12 bolt, and other drive train parts, that will add rotational mass.
Old Dec 4, 2004 | 07:50 PM
gtodoug's Avatar
I lost like 15whp with my 3.91 gears so doesn't sound too far off. It's gotta be the gearing.
Old Dec 4, 2004 | 11:04 PM
pkincy's Avatar
Could you post your dyno graphs, so we can see where the losses occurred?
Perry
Old Dec 4, 2004 | 11:13 PM
JS's Avatar
JS
I picked up .15 in ET/2.1 in MPH and this was run in DA's that were less than 50 FT apart.I dont know whats wrong with your setup but it was worth an easy 10/10 RW on my setup....
Old Dec 4, 2004 | 11:32 PM
Mike K.'s Avatar
gearing probably took some out of it, I only gained 10 hp and 5 tq with mine but the funny thing was is when my timing was reduced to 24 degrees and my 12 bolt was put in I only ended up losing about 20 hp which put me back right around the area that I was before I added the intake almost like the intake grew on my motor??
Old Dec 5, 2004 | 07:43 AM
We added the gears but it is in a Vette so no additional weight was added. I dont have the graph. Could it be the ports dont line up causing a turbulance. What is the best timing to be set at for the most power?
Old Dec 5, 2004 | 09:36 AM
dynocar's Avatar
I'm assuming that you before/after dynoed on a Dynojet and if you changed gears, this will unpredictably skew the results of your engine mods, too many changes at one time. If you dynoed on a properly operated good measureable load bearing dyno, there is a good probability that you have an engine mis-match somewhere. You stated, "We added the gears but it is in a Vette so no additional weight was added." Maybe it was a load bearing dyno, but if it is why would you add weight, gears weigh more? EJ
Old Dec 5, 2004 | 12:54 PM
Same dyno.
Old Dec 5, 2004 | 09:29 PM
onesweetz06's Avatar
Same dyno.
A lower gear will decrease RWHP, by how much who knows
