g5x3 dyno results...
Old Dec 23, 2004 | 04:07 PM
NicD's Avatar
7 Second Club
Originally Posted by Zombie
Most heads cam cars I do i'm able to get to 29-31 in summer (110+ temps) with ZERO knock.
I guarantee that won't happen in phoenix.
Old Dec 23, 2004 | 04:52 PM
BADSZ28's Avatar
My car is at or above 14:1 on the dyno and I put down that torque. And those conditions look pretty good to me. 70*, 22%humid., 28.6 in-Hg. Looks pretty good to me. Isn't this close to ideal? This is not a high compression, FI motor. It does not need more than 91. Seems like it needs more fuel, not timing. And again I did say nice HP increase.
Old Dec 23, 2004 | 07:42 PM
DVST8OR's Avatar
Originally Posted by SStolen
It looks like on your last dyno pull, the highest hp pull, that you were only putting down 552 rwtq.
That was the first run not the last. And it was 352, I wish it was what you typed.
Old Dec 23, 2004 | 09:21 PM
obrien24's Avatar
Originally Posted by chevysrule94
WOW!!!...What were you doin?? Drifting or somethin?? Thats unbelieveable to destroy both with next to stock HP and only 18K miles??
lol first off drifting is gay. Tell me about it, it cost me $3500 in less than a month. I bent the 3/4 shift fork and I quess the previous owner managed to waste 5th and 6th some how. As far as the rear, the previous owner did that as well launching it at the track on nittos. I think he did the damage, and it finally gave in when I had it. Less than 2 months after I bought it.
Bye the way nice dyno numbers. Forgot to put that in my first post.
Old Dec 24, 2004 | 03:31 AM
AZ Power & Sound's Avatar
Originally Posted by BADSZ28
Those #s seem low. Especially torque. I would expect that without headers maybe. Hell my minor bolt-on 02Z put down 361rwtq with 300@2500rpm. The HP increase is great though. 57hp is a nice jump for just a cam swap.
Keep in mind you are in IL with 93 octane, sea level conditions and MUCH more timing... his results are STELLAR for AZ conditions as the average out here for us is 380ish rwhp on the cam only cars... We generally get 30 or so rwhp less then the states with 93 octane... ESPECIALLY the ones at sea level!
Old Dec 24, 2004 | 03:34 AM
Originally Posted by wait4me
the reason why his torque is so low is, look at the air fuel, its almost 14:1 when it gets richer, the torque starts to go up more, that thing is starving for fuel..
it has plenty of fuel and its on a perfect tune... its only running 24 degrees of timing as we dont do agressive tunes unless requested... even then I still dont prefer to let them loose with that because soon as summer hits and the temps hit 120 degrees outside the thing starts knockin like a ex wife wanting her child support!
Old Dec 24, 2004 | 03:35 AM
Other way around... the last pull was the lowest hp number, but highest torque...
Old Dec 24, 2004 | 03:38 AM
I live in vegas and have tuned several cam only and h/c cars. The octane comment is ture, but I've never tuned less than 28 degrees on a cam/header setup. Most heads cam cars I do i'm able to get to 29-31 in summer (110+ temps) with ZERO knock. I do remap the IAT spark table so timing is automatically pulled during high temps to prevent knock.
I've gotten a few cam/longtube cars in the 370-380 range on 91 octane. All have cams under 232 i believe.
One of my friends has a 6.0 iron block setup with 11.0:1 comp and a 237/245/112 .590 cam. I've been able to get him to 30 degrees as well with zero knock (getting the daily driving good with a/c and all took some time though). Getting the timing up there is all about knowing what the motor wants and preventing ANY knock from occuring... well 1 degree once and a while is ok.
Cam selection plays a big role in the amount of timing. A vette I tuned had a 228/228/114 i believe. His comp was 11.2:1... with that cam and that compression it was too much for 91 octane. I tuned him and got the car running well, but I had to run the tune fat (like 12.0 a/f) during the tq peak and 12.4 everywhere else (I normally tune 12.7) just to keep the timing at a point where the car would run well. If he swapped to a larger cam with more overlap his setup would run much better. I was only able to get a MAX of 24 degrees on his setup and was down to 21 or so during the tq peak.
All the LS1s here knock even in stock form... we generally LOSE 20 rwhp adding a hypertech or diablosport tuner... our gas is REALLY bad here, and in the summer its packed with ether... which we all know makes it combust faster giving the fuel even worse characteristics... basically if it has a lot of timing the thing just knocks like crazy! I trust our tuners opinion on the tunes he gives and I choose not to let the cars leave with agressive tunes... Dynos are meant for tuning anyways... that number says nothing about how fast your car is.
Old Dec 24, 2004 | 03:44 AM
What you are failing to understand here is the fact that we DO NOT tune aggressively... Could we have scraped 10 horse more out on a one time tune? Sure... but what good does that do when march hits and its 100 degrees out, then he has to drive 150 miles to get a retune... then july hits and we get to 120 degrees out and our summer blend of gas hits the pumps... again another retune.
Our goal is to produce daily drivable cars that dont require maintenence. My car makes 443 rwhp with stock heads, stock bottom end and 4.11 gears... but I also get a retune every time the temps change drastically to keep the numbers that way. Not everyone wants to do that nor have to wonder if that bad tank of gas that AZ is known for will hit the car... then BOOM.
Not trying to flame you, just trying to help you understand that not everyone out there is trying to extract every little horsepower from their car at all times... if we had chicagos weather you can bet we would ALL be 20-30 horsepower higher... but proven fact taking a chicago car here will drop AT LEAST 1/2 second in the 1/4 and drop about 20 or so at the wheels.
Old Dec 24, 2004 | 12:15 PM
NicD's Avatar
7 Second Club
Actually it has 27-28 degrees in it.
Old Dec 24, 2004 | 01:27 PM
wait4me's Avatar
rich is safer than lean, and 14.1 is lean, that in my eyes is more dangerous than running a little more to the richer side, looking at the three runs you can see my point, the richer it gets the more torque it is making, 14.1 is not safe in my eyes... ask anyone else around that knows anything.. some people dont even like going as high as 13.0 to be a safe tune, they think that is way to lean.. 12.9 is the highest i would ever go, and on a turbo or super charged car the highest i would ever go would be a 12.2 and thats pushing it..
Old Dec 24, 2004 | 01:29 PM
  #32
wait4me's Avatar
another thing, if you are worried about fueling and timing issues in the summer, there are plenty of tables that take care of that issue in the computer so you dont have to worry about switching tunes all the time..
Old Dec 24, 2004 | 02:15 PM
  #33
NicD's Avatar
7 Second Club
agreed.
Yes, there is an IAT table to pull timing, which works great for the summer heat here in AZ. What it doesn't work for is the different blend of gas we get during certain months.
Old Dec 24, 2004 | 02:56 PM
  #34
DVST8OR's Avatar
Bottom line is, I am extremely happy with the performance of the car. She has no problem finding idle, including cold starts, I can run the A/C full blast and she doesn't even flinch. No stalling at lights, nothing. In fact, in day to day driving the only way I even know there is a cam there is at idle and when I press the go pedal.
Power band feels awesome, no dead spots, no waiting for power, and she pulls like a raped ape all the way to the 6800 rpm redline. And that is what matters to me, and if I had to sacrifice a couple of hp numbers to get a reliable tune (especially considering that she is my daily driver) I will gladly give up a few ponies according to a dyno sheet.
Old Dec 24, 2004 | 03:23 PM
  #35
tomss99's Avatar
haha too big of a cam on stock head cars i guess.... its all about under the curve woohooo
Old Dec 24, 2004 | 03:28 PM
  #36
wait4me's Avatar
i dont think you understand what i am saying, your tune at 14.1 isnt considered a safe tune.. 12.8 is considered a safe tune, anything leaner is not.. your "14.1" is leaner than a 12.8 therefore, is not safe.. normal drivability is not affected by pe mode, and the petable is just not set up correctly. that is all im saying, this is my last post on this, jes
Old Dec 24, 2004 | 05:20 PM
  #37
NicD's Avatar
7 Second Club
Are you color blind? I don't think you understand that the run with the 14.1 a/f was the first pull and he had a ported MAF and it was throwing everything off. I don't even understand why those two non-final runs made it on the print out anyways. He should have only gotten the last run (#4) with a final A/F of mid 12-high 12 throughout the entire pull on there. So I would appreciate it if you stopped telling him that his tune is not safe and that it isn't setup correctly. Thanks.
Old Dec 24, 2004 | 05:27 PM
  #38
freakynipples69's Avatar
After reading this post, should I risk throwing in 4.10's in my stock 10bolt and get a G5X3 as well??
Old Dec 24, 2004 | 06:17 PM
  #39
And if you look closer you will notice that the final run had the most torque and the best air fuel... Thats why its called dyno tuning... unless you have a new method of hitting it perfect on the first run.
Old Dec 24, 2004 | 07:10 PM
  #40
lilbuddy1587's Avatar
Too bad its a max effort cam designed for stock heads huh ?
Go home dude, ur lame comments have impressed no one
