g5x3 dyno results...
I can't wait to see if the pinging is around this summer now that Nic tuned my car.
And again Brian, nice numbers.
It is an "at your own risk thing." Some people have great luck and dont break them, some break them on the first launch. All I can say is dont get slicks and no 6,000 rpm dumps and you should be fine. While the stock 10-bolt is weak it is certainly not made of glass.
Just as I said on the other board, some people think that throwing the biggest cam in there car and calling it a day is going to make them the fastest/highest dynoing, etc.....as you already know. Just trying to get the point across to the um, slower folks.
Ok, so basically you're a dyno queen...as well as being apart of the esteemed Arizona $50K f-body club. Congrats.
We put our LT's on about the same time and I knew it would be just a matter of time before you cammed it!
but 12.3@117 in the middle of the day on drags with full weight and stereo is fine with me! I cant wait to get some X4 numbers, then someday I will strap on some stickies and make a full pass just to shut everyone up
2.0 60s are a bitch
Our goal is to produce daily drivable cars that dont require maintenence. My car makes 443 rwhp with stock heads, stock bottom end and 4.11 gears... but I also get a retune every time the temps change drastically to keep the numbers that way. Not everyone wants to do that nor have to wonder if that bad tank of gas that AZ is known for will hit the car... then BOOM.
Not trying to flame you, just trying to help you understand that not everyone out there is trying to extract every little horsepower from their car at all times... if we had chicagos weather you can bet we would ALL be 20-30 horsepower higher... but proven fact taking a chicago car here will drop AT LEAST 1/2 second in the 1/4 and drop about 20 or so at the wheels.
AZ after cam - AZ before cam =(aprox.) Chi After cam - Chi before cam
+57rwhp=good
+10rwtq=bad
+57rwhp=good
+10rwtq=bad
It looked a bit odd to me too, but with the installation of 4.10 gears I have only ever seen torque #s go down, more so when compared to the horsepower # on a dyno. So why the torque #s are lower than average? Got me, WOT tuning is the easiest part of a tune. It is running 28 degrees of timing with a mid 12 a/f ratio, it is fairly optimized and running more timing with 91 octane would be foolish. I would have to say a lot of it has to do with the fact that we live in a desert and our air sucks. Cars never dyno well here in AZ, nor do they ever run the numbers that a lot of guys do back east with great air.
