PLEASE post some corrected numbers. Uncorrected numbers can be WAY off, especially this time of year when it is cold outside.
Don't believe the first graph when it says uncorrected. In fact, WinPEP shows slightly different HP/TQ numbers everytime I open up my dyno files. By between 5-10 HP/TQ. Go figure. The scanned graph I posted later is not actually uncorrected or SAE, but STD, which according to the other printout I got is .99 of the uncorrected numbers. SAE was a little lower than the STD figures, putting it at the numbers in the first graph I posted, give or take a little according to how WinPEP was feeling at the time I opened the file.
the torquer curve with 15 more hp up top was on a 2002 with the 241 castings and an u/d pulley...
The 233/239 numbers were with no u/d pulley on a 2000. I talked to john at texas speed and he said they had a 233/239 dyno 415/403 with an u/d pulley true duals pacesetters and an ls6 intake on a 806 casting head, fwiw.
Sorry. WinPEP lied again. I plugged my numbers into the actual SAE equation and it came out to 383/354. Sorry for any confusion!
I've just had my Torquer installed on my 2002 T/A,It is in need of a tune,it was dying out at almost every stop, I had to put in Neutral and give it gas when I slowed down or car would die out.My setup is Whisper lid,Dual valve spring kit from TSP,TCI 3500,Pacesetter LT,Flowmaster,Taylor10.4mm,NGKTR6.How long did you drive w stock tune,and is there a how to section on how to drill out TB,to make car driveable?Did you notice a big difference driveability wise w/tune?Has anybody had a TSP mail order tune with this cam?
For starters I turned in the TB set screw about 1 1/2 turns. This helped tremendously. I eventually turned it most of the way back out, and drilled the TB out a few sizes, which seemed to work the best. You'll have to experiment a little with this step. I had a buddy tweak a few things with the idle decay and stuff like that to help with it stalling out, but it's still pretty much untuned. Gonna finish her up when I get HPTuner here soon. Do the above steps for now, and either get HPTuner and tune it yourself, or have TSP do a mail order tune. I imagine they would do a pretty good job. You may or may not have a good local tuner, and it can be a real hit and miss proposition as far as finding someone who knows what they are doing. Ask around your local forum and see if there is a person/shop that is recommended.
