RAPID Dominator 402 CI LS2: 553rwhp!
#81
Originally Posted by speedracer5532
It is a 402 because the LS2 has a 4 inch bore and you can't bore the sleeve in the aluminum block 30 thousandths. You could re-sleeve the block but that gets expensive.
#82
LS1TECH Sponsor
Ty (LoudSS) picked up the car today to get it inspected and we'll be finishing up the tuning after we have 1000 miles on the motor. He will be in here later to let you know his impressions
![Grin](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_grin.gif)
#86
LS1TECH Sponsor
Originally Posted by CANNIBAL
How has your success been with that SPEC III? Do you also run the billet flywheel?
#93
Originally Posted by lewi1032
what roughly is the cam specs.....I am building a 408 A4 and really would love for any input!!!
read the post, he gave rough specs already:
Mikey: Cam is proprietary for now but the lobes are based on our Dominator series cams (55mm). Spec if 244/250/113 0.612 / 0.610 ICL = 110*
#97
Originally Posted by kumar75150
very nice numbers
I wonder why the Vette with the 408 is making less power with a very similar setup.
#99
Originally Posted by ezss
same reason some h/c cars make way more than others. It comes down to doing the legwork/research/engineering and coming out with a combo that really works well together.
honest question
#100
do you think who grinds the cam makes that much difference although the sizes are similar?
honest question
honest question
So cam, compression, intake setup (Ty's lsx is ported/port matched for instance), tuning all make a big difference in power. Internal components setup, pistons, lifters etc.. also have an impact, as does valvetrain setup (rockers, springs, etc...). Although the impact can be smaller, if everything is speced out and setup with a plan from the start, then you get a combination that really maximizes the power potential. Heads porting also varies hugely, but in the case of two cars with AFRs its going to come down to the other factors if there is a large variance in power.
