New F13 dynos...
Old Mar 19, 2005 | 04:34 PM
SideStep's Avatar
Default New F13 dynos...
Finally dynoed after cam swap...
SAE
old
412.5rwhp 393.4rwtq
SAE
new
422.9rwhp 406.8rwtq
My car has historically been a lower dyno'er so maybe these numbers are right....???
Will post the dyno-graph asap...
Old Mar 19, 2005 | 04:55 PM
jrp's Avatar
jrp
SN95 Director
your going from the G1 to the FM13 right? and get the graph up , i want to see the curves.
Old Mar 19, 2005 | 05:15 PM
SideStep's Avatar
yupper... G1 (115lsa) to a F13 (112lsa) both had +4 advance
Old Mar 19, 2005 | 05:19 PM
jrp's Avatar
jrp
SN95 Director
why'd you dump the G1, i know how much you loved it
to bad you didnt have the G1 on the same 112lsa and 108 icl, just by that nature the FM13 should have better low/mid range tq curve.
Old Mar 19, 2005 | 05:37 PM
SideStep's Avatar
Yes I did....
I apologise about the quality and size of these pics... scanner is broke...
I am going to add some more timing from 3000-3500 and try to pull the dip up...
...I can tell a differnce but the SOTP meter is a hard read.
G1
F13
...and for the record it was not the hardware, but the customer service.
Old Mar 19, 2005 | 05:53 PM
jrp's Avatar
jrp
SN95 Director
dang, i was hoping they were from the same dyno. none the less
Old Mar 19, 2005 | 05:54 PM
SideStep's Avatar
I will, but it will be in three weeks, when I am back in Atlanta...
Old Mar 19, 2005 | 06:38 PM
Bo White's Avatar
jlaws car has the same dip as yours. Those #s are through the exhaust? When jlaw uncapped his car the curve straightened out
www.ls1tech.com/forums/showthread.php?t=286127
Old Mar 19, 2005 | 06:41 PM
SideStep's Avatar
...aahhh, now that is good info... yes, I am running a complete exhaust system with cats...
He (jlaw) put down 425/400 through full exhaust but with no cats, right???
If so maybe these numbers are normal...
Old Mar 19, 2005 | 06:44 PM
Bo White's Avatar
His car put down 422/398 through the exhaust no cats so uncapped your car will probably put down somewere around 440
Old Mar 19, 2005 | 06:46 PM
SideStep's Avatar
LOL...
I guess we were typing at the same time....
Sweet, good to know...
Old Mar 22, 2005 | 04:28 PM
DravenMyers's Avatar
Nice numbers I hope to some good results also,my cam should be getting here any time soon FM is trying to locate me pulley.How does the cam sound to you and hows the idle?I want my car to be loud as **** and have nice lobe sound also how does it drive.
Old Mar 22, 2005 | 06:14 PM
SideStep's Avatar
There are 3 sound files in my Sig. To be honest with you the idle is so good I could have went with a bigger (F14) cam. I have the idle set to 900, you will get more chop if you bring it down to 850 or 800 rpms. Loud is a function of your exhaust system. Mine is very tame at part throttle but screams at WOT. Take a listen at the drive-by video.
Good luck, you made a good chioce...
Old Mar 22, 2005 | 06:36 PM
Wicked_Hugger99's Avatar
that drive-by is badass!!!!!!!!!!!!!!!!!!!!!
Old Mar 22, 2005 | 08:44 PM
SideStep's Avatar
Thanks... been wondering what it would sound like with-out cats..???
...may shave heads also.
Old Mar 22, 2005 | 09:25 PM
I am going with long tubes no cats and corsa,I will try a idle at 900 to see if I like it.I am going from a stock cam to fm13 will I notice a big power diffrence at WOT next years project will be 100 shot
Old Mar 22, 2005 | 09:59 PM
WS6FirebirdTA00's Avatar
ive got an f13 goin in with AFR heads, i wonder what kinda power i can make, i bet it would sound sweet through my exhaust, yours sounded sweet by the way. id like to know how much the heads can be milled iwth the f13
Old Mar 22, 2005 | 10:41 PM
jlaw's Avatar
Good numbers. I added a catback and plan on re-dynoing soon, I want some good capped #'s. We only made one pull with the cutouts closed, and some changes were made to my tune after they were opened.
Old Mar 22, 2005 | 11:43 PM
bigeller's Avatar
I agree.. Nice.. Bet you'd pick up more by retarding the cam to 0..
Old Mar 22, 2005 | 11:56 PM
SideStep's Avatar
ooohh yes... you are in for a surprise...
By Brett Foote | 2026-06-04 05:00:17
