F15 cam only results
Old Apr 3, 2005 | 03:08 PM
gomer's Avatar
Default F15 cam only results
I sold the heads off my car back in December and have had a set of stock 853's off 2bseen's car on it since then. I was tuning a bunch of cars at Walker Dynotune yesterday and when we got finished up I decided to see what mine would do with the big cam and stock heads. I wasn't expecting too much with the fresh 4.33 gear'd 12 bolt and steel drive shaft, but it didn't turn out half bad. I'm pulling the F15 out tonight and installing a MS3 in it and I'll redyno next week. After that I'm going to add the FAST 90mm intake and NW tb on it. The first graph is as I drove it down there and the cutout open (67 miles one way) the pull that ended early on that graph would have been a little better than the first, but it blew the wideband out and the operator let out of it, the second graph shows how much was gained by pulling the air filter and belt off it for a pull.
To recap the mods on the car. Stock 31,000 mile shortblock with flycut pistons, stock fuel system, underdrive pulley, electric waterpump, lid, Bo White ported TB, stock LS6 intake, stock 5.7 heads, hooker full lengths with offroad Y pipe, hooker cat back, cutout.
The drivetrain is a moser 12 bolt with 33 spline axles, eaton HD, Richmond 4.33 gears, and a APE chromoly steel driveshaft... spinning 17x11 rear wheels.
Old Apr 3, 2005 | 06:07 PM
Brandon Boomhauer's Avatar
Nice TQ curve there..
What are the 853 heads?
I have 241s on mine.... guessing a year difference? (never really paid attention to that for some reason...)
Old Apr 3, 2005 | 07:02 PM
gomer's Avatar
They are stock 99-2000 (and early 2001) 5.7 LS1 heads. They aren't as good as the 241's from what I hear.
Old Apr 3, 2005 | 08:34 PM
Bo White's Avatar
Is the MS3 cam the one you are going to run with the ported 241s your gonna get?
Old Apr 3, 2005 | 08:55 PM
gomer's Avatar
Yep, I have to flycut for the exhausts before I install the ported heads though. I'm going to dyno it with the MS3, stock heads, and 90/90 combo before I add the ported 241's.
Old Apr 3, 2005 | 11:18 PM
Thanks for the clarification on that gomer.
Thoughts on my F14?
Old Apr 4, 2005 | 01:21 AM
Wicked_Hugger99's Avatar
pretty good numbers i think
Old Apr 4, 2005 | 01:59 AM
BOWTIE's Avatar
What is the MS3 cam? What are your feelings about the F15? I am thinking about about either the F14 or F15 for my M6. I thought I had decided on the F15 until I read some post about people not being impressed (one in particular comes to mind where he pulled out an F13 for the F15 and made less power, so he went back to the F13 and found his lost power).
Old Apr 4, 2005 | 05:13 AM
Magic Stick cam from TSP...237/242 .603/.609 on a 113lsa i believe
You gotta remember these F15 numbers are through a 12-bolt w/ 4.33 gears and steel D.S. but as most folks say its the ETs and trap speed that count, not dyno numbers
Old Apr 4, 2005 | 07:00 AM
gomer's Avatar
I'm not a big fan of the F15. Look at my second graph where the operator turned the engine up a little higher, notice how right after it peaks, the power drops off VERY quickly. The cam is very "peaky", it doesn't have a nice flat peak HP. There is no way I'd install or buy a F15 over a F13. My OPINION is that the 110lsa and 107icl of the F15 hurts it, I'm thinking the MS3 with it's 113lsa and 113icl, will have a flatter peak and won't fall off so quickly.
Old Apr 4, 2005 | 08:28 AM
Did you tune this setup Gomer?
Arent you also the guy thats gonna tune Armageddons car? if so cool, ill get to meet ya cuz i think im gonna go w/ him when he straps it down on the rollers.
Old Apr 4, 2005 | 08:33 AM
gomer's Avatar
Yes, I did the tuning on it and will be doing Armageddon's car too. I had 7 or 8 cars at the dyno this past Saturday, so there was ALOT of tuning going on
Old Apr 4, 2005 | 10:41 AM
Bo White's Avatar
With the LS1s effiecient combustion chamber such a tight LSA is not required like it is on the sbc. Rule of thumb is if you advance the ICL and gain power the cam was too big to begin with and if you gain power by retarding it the cam isnt big enough to optimize the engines potential. A 108 ICL is as far as I like to see them put in at and 114 as retarded as I would like. Just my thoughts
Old Apr 4, 2005 | 11:29 AM
Isnt he coming to ya this weekend?
Where do you tune at? got ur own shop/dyno?
Old Apr 12, 2005 | 05:21 PM
Bo White's Avatar
Bumpin this thread for comparison with the ported 241 heads dyno #s since gomer is goin to stay with this cam for now. These 241s are some heads I done for gomer to test and to run at the shootout on the 30th of this month.
Old Apr 12, 2005 | 11:03 PM
So what did ya do to the heads? stock valves and just a hand finish, or a full port?
Old Apr 13, 2005 | 07:41 AM
gomer's Avatar
They have REV 2.02 intake valves, stock exhaust valves, and hand ported/polished.. overall a really cheap setup. I'll be installing them on the car late next week sometimes and dynoing it again.
Old Apr 13, 2005 | 09:22 AM
Bo White's Avatar
The heads are milled .010" and have 220cc intake ports and 82cc exhaust ports- the combustion chambers will be around 68cc. If they were flowed they would probably go 280/220 @ .600 or better.
Old Apr 13, 2005 | 10:00 AM
DOUBT IT's Avatar
Them were some pretty heads.
Hey gomer, you gonna be at the Birmingham FBA Dyno Day in May? If so, I may come up there and have you change my cooling fan settings... That and see how much more Bo's TB got me.
Old Apr 13, 2005 | 10:01 AM
tomss99's Avatar
my 225/225/ .595/.595 114 gave me great results untuned.... made 404.56 and 379.86 torque with slp longtubes, ory, asp pulley, and the rest of the small bolt ons.... with an air fuel that doesnt go above 12.0....i wonder if ill gain ate least 5 rwhp from a tune
