1998 A4 Dyno let down
Old Apr 4, 2005 | 12:17 AM
RollinThunder98's Avatar
Angry 1998 A4 Dyno let down
I have a 1998 Z28 A4(124K miles) with a Hooker Cat back, Pacesetter LT's, TSP ORY, LS6 intake, lid, descreened MAF. Had it dyno'd this past weekend, and only dyno'd 308 HP, 330 TQ on the baseline, and tuned up to 326 HP, 339 TQ. Although it feels much better after the tune, I was expecting higher #'s. Was I wrong to expect #'s closer to 340 HP and 350 TQ? BTW,Dyno was done at Walker Dynotune on a Dynojet Dyno in Trussville, AL.
Old Apr 4, 2005 | 12:22 AM
LS1_PNYTAMR's Avatar
thast pretty damn good.. a guy i knew with same mods dynoed 318, 99', and another 301 only with a 02 model heads/ls6 intake.
Old Apr 4, 2005 | 12:25 AM
bigeller's Avatar
You need a cam..
Old Apr 4, 2005 | 12:29 AM
BlueSix's Avatar
Your numbers are fine for your mods. You have an A4, they don't dyno as high as the M6 cars.
Put a stock screened MAF back in though.
Old Apr 4, 2005 | 12:30 AM
1 BLOWN V8's Avatar
Do you also have a stall? A cam would bring the #'s where you want them.
Old Apr 4, 2005 | 12:32 AM
luv2spd's Avatar
Could be a little higher but not bad for a 98 A4 with those miles.
beardWS6's Avatar
If you where a 6sp you would have gotten another 10-20rwhp. That would have put you where you wanted to be. A4`s arn`t good for dyno numbers. Take it to the track!
Old Apr 4, 2005 | 12:33 AM
Question
No stall yet, any opinions on a TCI SSF 3500 though?
Old Apr 4, 2005 | 12:37 AM
1 BLOWN V8's Avatar
I went with a tci also. That one is a great choice. Just dont forget to add a trans-go shift kit and a trans cooler.
Also with a stall your #'s will be even lower but its due to the stall.
Yes, yes and yes on the stall. You should have done that first. I wasn't sure either about doing a stall. But all I can say now is WOW.
Old Apr 4, 2005 | 12:46 AM
badata's Avatar
those numbers sound good to me, any major problems yet with those miles? i love my tci, its just alot harder to get a good launch without spinning. with the tc your dyno will be lower but you will be able to feel more power when driving
Old Apr 4, 2005 | 12:48 AM
No major problems yet, but according to the dyno, investing in some new springs wouldnt be a bad idea.
Old Apr 4, 2005 | 12:52 AM
mshadow's Avatar
I have a 1998 A4 with 90,000 on it....
I made 343rwhp 362tq Pacesetters LTs, Trueduals, Descreened MAF, Jantzer TB, ASP pulley, LS1 intake...
You got new plugs/wires/fuel filter/do a top end cleaner?
Old Apr 4, 2005 | 01:01 AM
I had a set of Taylor wires and NGK plugs put on at about 105K. Have not changed fuel filter or did top end cleaner.
Old Apr 4, 2005 | 01:18 AM
Wicked_Hugger99's Avatar
baseline on my 98 TA a4 was 326rwhp locked stock verter w/ Lt's, ls6intake, all the other usual bolt-ons. Id say ur #s are pretty damn good
Old Apr 4, 2005 | 08:16 AM
gomer's Avatar
You might want to think about adding a ported TB and an ASP pulley on the car, that will help the dyno numbers a good bit. I thought the car did pretty good for the mods and miles. 98's aren't really known for big numbers.
Old Apr 4, 2005 | 09:48 AM
Spdmini's Avatar
I agree, you dont want all types of crap getting into the engine for a couple HP. also with a full exhaust and a lid i put down 308 and 330. i wouldnt be too worried about the numbers, they are just that.
Old Apr 4, 2005 | 09:56 AM
john3daly's Avatar
Damn...that's awesome.
For your reference, before the stall I put down 325/34x. After the stall and descreened MAF (for nitrous) I put down 305/33x but the car was MUCH faster.
Your numbers don't sound far off. Go to the track and run it the way it sits. Then get a stall and lose some hp, then run it again. Tell me dyno numbers don't lie...
Old Apr 4, 2005 | 11:43 AM
dynocar's Avatar
"Tell me dyno numbers don't lie..."
They don't, if you have a good dyno and knowledgeable operator who educates the public. When comparing TC stalls, some give a graph comparison of the force/MPH of the tire's patch at the dyno's roller. This gives a very clear picture of how the drive train torque multipication derived from different stalls helps acceleration. Being able to get the RPMs up on the engines HP curve quicker always translates to more TQ at the rear axle and more forward force at the tire's contact patch, if done properly.
