Help!!!!!!!!!!!!! Wtf
Old Apr 18, 2005 | 04:21 PM
VIPER EATER's Avatar
Default Help!!!!!!!!!!!!! Wtf
ok i dunno what happened but i dynoed my car this last saturday and i was very depressed. over the winter all i did was gutted my cats and before i did anything i dynoed 332/345 stock with lid ok and now that i have gutted the cats and through a cut-out i dynoed 312/324. and then on the bottle i did 437/489 before gutting the cats and now im at 400/430 so what the hell is the dyno messed up or is gutting the cats a bad idea any ideas and help is greatly appreciated so let me know
Thanks Jason
Old Apr 18, 2005 | 04:30 PM
30th t/a's Avatar
maybe you messed up your a/f ratio.
i had my car tuned with a magnaflow catback then installed 3" duals and lost 15rwhp because my a/f went from 13:0 to 11.8.1.
Old Apr 18, 2005 | 05:19 PM
i see what your saying but on the motor run it was almost identical as it was before so it didnt richen up nor did it get lean it was still the same i dont have the sheet in front of me but i think it was 12.5 or so a little rich but i think it was the same and on the bottle it was i think 11.2 or so and i have a 150 nitrous jet in the fogger with a 125 fuel jet in the fogger and it ran the rich still so i dunno any other ideas would be helpful
Thanks Jason
Old Apr 18, 2005 | 05:31 PM
pdd's Avatar
pdd
you sure all the crap is out of the cats. maybe theres some **** in there blocking up the exhaust flow????
Old Apr 18, 2005 | 06:35 PM
yeah im sure all the stuff is out of the cats cause there was paper left in the cats and we took some gas and poured it down the cat and lit all the paper on fire and got all the stuff out of it so yeah there as hollow as they will get so i dunno. am i suppose to lose power buy guttin the cats i wasnt really expecting to gain anything it just sounds good so i dunno let me know thanks
Jason
Old Apr 18, 2005 | 08:11 PM
deetsnai's Avatar
reset ur ecm/pcm, give it a couple days and see what happens, or get a tune
Old Apr 19, 2005 | 01:58 AM
v8-7's Avatar
are you still running the rear o2 sensors? They will read differently if there are no cats, or in your case, gutted cats. Im sure that would cause a problem...
Old Apr 19, 2005 | 07:55 AM
JoeyGC5's Avatar
Beat a pipe into/through the cat or cut them off completely. Gutted cats sometimes tend to cause more turbulent airflow. Noob opinion anyway . Just as an example. I gutted my factory rear cats (front were lost in header install), lost 5hp/12tq. Cut the damn things off (no front or rear cats now) and gained about 14hp/8tq over the starting point.
 Michael S. Palmer
Old Apr 20, 2005 | 02:22 PM
see i have the rear 02 simms so there telling the computer that everything is infact ok so i dunno keep em coming guys until i can figure out what the problem is thanks for all your help
Jason
Old Apr 20, 2005 | 02:46 PM
Camaro ChriSS's Avatar
Same dyno? Are those corrected numbers? If 'no' to either of those, then that could easily be it.
Old Apr 20, 2005 | 02:52 PM
foff667's Avatar
LS1TECH Sponsor
Old Apr 20, 2005 | 03:51 PM
yeah it was the same dyno cause we only have one here in town so yeah it was the same dyno and yes the numbers are corrected. the only thing that is different is that before it was in the air and since my last dyno(the one where i dynoed 332) he's put it in the ground so what i was thinking is that he screwed up the dyno by putting it in the ground so i dunno any more help is appreciated
Thanks Jason
