452 rwhp - no head work...
2003 6.0 LQ4
heads milled .030
stock head gaskets and gm bolts
custom grind comp 232/238 595/605 112+2
comp 918's and Ti retainers
ported Mac Mids with 3" merge
dual 3 magnaflows
ASP underdrive pulley
home ported TB
truck intake
8.1L truck injectors (32#)
LS1Edit
custom intake setup with round K&N filter
Spec 3 clutch/steel fly not
steel driveshaft
12 bolt truck rear with 305/45/18 nitto drags
Best run: 452/422 on a dynojet above ground dyno.
Now have a aluminum flywheel so prolly close to 460. Absolutly no port or polish or cleanup work done on the heads.
I was impressed, anyone had similar results?
2003 6.0 LQ4
heads milled .030
dual 3 magnaflows
home ported TB
truck intake
LS1Edit
steel driveshaft
maybe its just me but shaving heads to increase compression is in the headwork category
I guess it just depends on how you look at it. If I had gotten the LQ9 block I wouldn't have needed to mill them because the compression is stock where mine is now. I mean the 5.7 is 10:2 stock. So am I...
or even, what does it rev out to? Cant be as high as a Ls1, can it?
Any graph, interesting motor and combo.!
