Possible for 350rwhp with bolt ons only?
Old Apr 26, 2005 | 03:24 PM
MachoCamacho's Avatar
^^^word^^^
Old Apr 26, 2005 | 08:58 PM
Scoobie's Avatar
I am in the process of trying to hit 400 RWHP bolt on only. I know some will laugh, but i am considering 1.8 Rockers as a bolt on to achieve this. The parts will include:
1.8 Rocker Arms with 918 springs.
90/90 set up
Kooks LT Headers
True Dual exhaust
Electric Water pump
ASP pulley
Lid
36 lb hour injectors
3.42 gears
Carbon Fiber DS
Aluminum Flywheel
Tuning, Tuning, Tuning
And whatever else it takes. Stock Heads, Stock Cam though
If i cant hit it, ill do a set off untouched LS6 Heads just to see the results
Understand that this is project of mine, all the parts listed above will complement any heads/cam set up i go for with perhaps a rocker and spring switch out. Id just like to see if it can be done
So far i have almost half the parts in my garage. I will dyno lid only, with the LS6 intake, then i will dyno with parts and tune for each additional add on. It will take time
and money but should be fun
-scoobs
Old Apr 26, 2005 | 09:16 PM
WAHUSKER's Avatar
Yes you can hit 350 with bolt-ons, and 400 with a cam. I hit 305 stock, ~345 with headers, lid, MAF ends & a Predator tune thru an A4. And then 391 with an LSX intake, Hot Cam & 1.8 rockers. Now that I have a 9" w/4.11s & a 3200 stall, my dyno bragging days are over. It's all about track times now. Full weight, cam-only 11s are coming....which has never been done here in Seattle. Yet.
Old Apr 27, 2005 | 09:45 AM
GrannySShifting's Avatar
Yes absolutely possibly. DO all your boltons first!
With lid, jethot longtubes and ported tb, made 346 hp/370 ft lbs, with a little tuning f course
Old Apr 28, 2005 | 07:21 AM
lsx24's Avatar
I uploaded a badass tune from Strickly Performance Motorsports and made the numbers in my sig by building this dynamic combination (which I would like to mention is 50 state legal): suncoast intake setup, ported tb, ported ls6 intake manifold, asp pulley, jba shorties, carsound cats, bassani true dual exhaust system, 4.10s and alum flywheel (which actually counteract each other, but are flat out awesome on the street).
Old Apr 29, 2005 | 02:46 PM
2001stripper's Avatar
Originally Posted by racinbird
Im sure this has been talked about before but the search didnt come up with anything.
What I have 2000z28 M6, FRA, SLP lid, LS6 intake, weld-on SFC's, LCA's, cut out and TR55's.
Is it possible to hit the 350rwhp mark with some LT's, high flow cats, true-duals with x-pipe, underdrive pulley, good dyno tune and a ported/polished TB. Perhaps even higher ratio rockers to push it over the edge.
what do you think?
Yes it is very possible. Check out my sig.
Old Apr 29, 2005 | 03:56 PM
Sick14SecV6's Avatar
How about these numbers 224/242 V6 Camaro 5sp!!
Don't worry I am upgrading to an ls1 shortly!
Old May 1, 2005 | 08:36 PM
Ptvolly's Avatar
I just found out the answer to this question!!!
I just dyno'd a couple days ago for first time:
350.0 hp
354.8 torque
This was on a mustang dyno, with a fuel pump that either isn't keeping up or is going bad, and the only mods I have are in my sig. (was being tuned while on dyno which is not in sig)
Old May 11, 2005 | 10:31 PM
Steve C.'s Avatar
Im pretty close with bolt ons......
Old May 12, 2005 | 12:24 PM
txhorns281's Avatar
On "that" dyno:
SAE 362/368 through powercats, full bolt-on, no dyno tricks, great tune...
I think I have the dyno posted in here a loooong time ago.
Old May 13, 2005 | 12:18 AM
Brandon Boomhauer's Avatar
I made 350/370 lid/LTs/Duals on a dyno that is known to show about 10 low
Its very possible IMO.
Old May 13, 2005 | 11:40 AM
  #32
Silver 00 SS's Avatar
With out a LS6 intake i made 348hp and 358 tq
Scott
Old May 13, 2005 | 12:19 PM
  #33
8GTOKLR's Avatar
Shouldnt be that hard to pull 350+ at the wheels when you already have 290-315 from the factory. I should be close will the mods below and there is only 4.. I still need to be dynoed also. Plus 400 on the motor should be plenty for street thats like 2 to 3 times what everyone else has dam 170hp 2.5L cars
2000 6SPD 65,000 MILES. MOD: HYPERTECH, WS6STORE SHORT STICK, FLOWMASTER MUFFLER, MONROE SENSE-A-TRACK SHOCKS, SLP LID & BELLOW
Old May 14, 2005 | 01:58 PM
  #34
68ss_00ss_87_95's Avatar
Default results
up here in maine i dynod at 333rwhp/355rwtq, all i gots, slp lid, bbk tb, granatelli mas, hypertech, cat back flowmaster
Old May 14, 2005 | 02:11 PM
  #35
Worm's Avatar
Definately possible I made 335rwhp SAE with a lid/loudmouth.
