f14 w/ disappointing nitrous results
Old May 3, 2005 | 05:21 PM
The Juggernaut's Avatar
It sounds like a fuel problem(torque).(Fuel solenoid, filter,something)
which would inturn possibly pop the head gasket.
I would sent the noid in to be checked , or check it yourself.
Old May 3, 2005 | 05:45 PM
Wicked_Hugger99's Avatar
what would i be looking for? Im a nitrous newbie
Old May 3, 2005 | 06:31 PM
Futral's Avatar
Well jetting the fuel side worsened the condition,even at an A\F of 10.4.
Eliminated the fuel solenoid and tried it as a dry system with an A\F of 10.8.
Like the previous post,the fuel system is working properly.
Old May 3, 2005 | 06:43 PM
383LQ4SS's Avatar
Can you post a graph? Weird thing I have seen more than once now that causes this...especially on juice. Belt slippage. DOnt ask me how....but if the belt slips on juice you can get WILD surging. Your only hint MAY be a little bit of belt dust. Both cars that did this were fixed with a Katech belt tensioner.
Allan...Vince was one of these guys when he had the SS.
The other things I have seen cause surging is too big of a plug gap...but it appears you tried different gaps. If you suspect the noids cycling at all just hook up a test light to the noids and watch them during the runs.
Oh...last thing...pull the valve off the bottle and make sure there is a pickup tube installed.
But my guess goes to slipping belt after reading the things youve checked.
Old May 3, 2005 | 07:51 PM
camaro98z28's Avatar
I hope someone figures it out before I get the F14 cam or I will just get the F7 cam
Old May 3, 2005 | 08:39 PM
INVISIBLEZ's Avatar
The engine numbers alone sound a little low considering my FM11 with a stock pulley and T.B. put 390 r.w.h.p. Something is definatly wrong.
Old May 3, 2005 | 10:51 PM
1LOUD98's Avatar
390 with a 6spd,your going to make more power than an auto!My car with a fresh bottomend same cam made 393 unlocked so i guess you think somthing must be wrong with my motor?What he made is about right for what he has.
Old May 4, 2005 | 05:03 PM
INVISIBLEZ's Avatar
Originally Posted by 1LOUD93
My car with a fresh bottomend same cam made 393 unlocked so i guess you think somthing must be wrong with my motor?he
I thought his car was a M6, sorry, no need to be a smartass.
Old May 4, 2005 | 05:59 PM
1LOUD98's Avatar
Was not trying to be a smart ***,its plain as day in his list 98 A4!
Old May 4, 2005 | 06:50 PM
INVISIBLEZ's Avatar
No prob. I read too many sigs....
Old May 4, 2005 | 11:57 PM
Brandon Boomhauer's Avatar
sounds like the same thing ravenoutst/a is having with his..
Old May 5, 2005 | 01:27 AM
  #32
383LQ4SS's Avatar
check the belt. Rig something up to keep it tight and redyno.
Old May 5, 2005 | 08:15 PM
  #33
TransamZed's Avatar
If ya already checked fuel system internel possibly injectors fuel system external.
