ls1 383 140shot
The valve springs are the patriot gold springs. I am using the luca 42lbs (for the dry shot) 340 fuel pump. The cam was installed dot to dot
What cam do you recommend (jrp) with my 9.8 cr?
or do what beast said and opt for a new set of heads and have them setup for your application.
4.00 stroke
62.38cc (ls1 head milled .030)
.040 cometic gasket
3.910 gasket bore
-.008 deck height (used OEM specs, you can measure yours for specifics)
9cc dish
11.1060 SCR
ptv clearance shouldnt be a problem as i assume pistons are 2cc valve reliefs with a 7cc dish.
9.8 SCR coupled with a cam thats got 17.5* overlap
1) valves sizes, port volumes, and head flow of said heads
2) valve springs used
3) head gasket and deck height
4) fuel system
5) ICL cam was installed on.
9.8 SCR? WTF? The valve springs are the patriot gold springs. I am using the luca 42lbs (for the dry shot) 340 fuel pump. The cam was installed dot to dot
What cam do you recommend (jrp) with my 9.8 cr?[QUOTE]
